Home > Help Needed / General Tech Chat > Drive Shafts
Is it possible to get them the wrong way around? I mean left one on right and right one on left? I noticed my pot joint had slid out the other day dispensing oil. I havent really had time to check, just thinking of any reasons with it would have moved.
Ben H
Member #: 184
Melton Mowbray, Pie Country
The only fit one one side. the most likely cause it the retaining clip on the end of the diff output shaft is missing.
http://www.twin-turbo.co.uk
richminiturbo.
Member #: 719
Horndean - Near Portsmouth
Ones about 3" longer than the other.
As Ben said, check the circlip on the spline of the output shaft, one of mine came loose and I double checked the circlip, looked ok but was actually in 2 pieces with a film of oil holding it together!
Edited by richminiturbo. on 20th May, 2009.
righty tighty, ill check it out.
Gavin Wakely
Member #: 793
A friend recently got the shafts the wrong way round, as in the outer C.V end in the pot joint end. The car drove but after a mile or so the shaft came out of the pot joint.
I havent had a prob to that extent, just my pot slid from the gearbox just enough to leak oil.
