Home > Wanted > Oil pipe, block-filter body
richminiturbo.
Member #: 719
Horndean - Near Portsmouth
Anyone have something along the lines of this:
http://www.minispares.com/Product.aspx?ty=...ED%20OIL%20FE...
Braided or rubber, that theyre willing to swap for an oil cooler including piping?
just use one of the cooler pipes?
richminiturbo.
Member #: 719
Both ends are male into the block and filter housing, unfortunately the pipes I have are male on one end and female joints onto the oil cooler.
Might see if they do an adapter actually.
Ive got adapters rich
which end do you need and whats your address?
richminiturbo.
Member #: 719
Joey you championé!!
What I have at the moment look like this:
(But without the bent fixture).
So I guess it's a male-male adapter that goes in the end of the female oil hose and then into the filter housing!
Are the filter housing threads and block threads the same?
If you have one like that Joey it'd be amazing, how much would you be after?
Edit- looking at that pic the threads are different sizes for the filter hosung and block oil passage, so either/or would be perfect buddy.
Edited by richminiturbo. on 20th May, 2009.
can sort you with a standard solid pipe if you so wish?
That way you can sell the cooler set-up as one?
oh actually?! isnt the SPI filter head a different thread? Anyone?
I've got loads of standard oil filter heads and pipes if you want one
richminiturbo.
Member #: 719
Ahh awesome thanks matey!!
I did have the standard metal pipe but I think it got bent haha.
Anyone know the threads?
are you sorted for these now rich?
