| Home > General Chat > spi head and mg head? | |||||||
20th May, 2009 at 02:25:55pm
is there much difference?
Yes i moved to the darkside |
20th May, 2009 at 02:28:03pm
The late MG ones where unleaded. The had slightly smaller valves than the leaded MG. should go straigt on. On 11th Feb, 2015 robert said:
20th May, 2009 at 02:30:37pm
No difference apart from MG/Cooper SPI heads flowed better than the standard ones. If something is worth doing, it's worth doing half of. |
20th May, 2009 at 02:35:33pm
On 20th May, 2009 minimadmotorman said:
No difference apart from MG/Cooper SPI heads flowed better than the standard ones. so they are basically the same? i might aswell just swap it then if i need to.. Yes i moved to the darkside |
20th May, 2009 at 02:38:10pm
Correct. Just make sure its tapped for heater & temp sender.
20th May, 2009 at 02:41:47pm
Correct. Just make sure its tapped for heater & temp sender. If not do it yourself :) i cant remember, lol doubt ill have the tap for it tbh any ideas on the thread? (the the sender) i can sort the tap
Edited by Brett on 20th May, 2009. Yes i moved to the darkside |
20th May, 2009 at 07:41:11pm
There are NO heads which have 35.6mm inlets and are unldeaded. That means, no MG Metros were unleaded.
20th May, 2009 at 07:53:42pm
Evening Vegard
20th May, 2009 at 08:03:18pm
OK, I was under the impression that the MG Metro egnines were killed off by then.
20th May, 2009 at 08:18:08pm
The SPI head has the 33/29 valves, like the unleaded MG heads, the earlier MG heads as said had the larger 35.6mm inlet.
