Home > Help Needed / General Tech Chat > Rock solid ball joint
Carl S
Member #: 1761
Stalker
Hi folks, anyone had trouble with removing lower ball joints before? I'm having great difficulty removing the driver side lower ball joint dome nut (the cup that holds the swivel pin in), i spent a few hours trying to free it up with a ball joint socket and ratchet but it wouldn't budge one bit.
Any ideas for freeing it up without removing the hub? Is this a common problem?
Edited by Carl S on 20th May, 2009.
yes it common, use a blow lamp and get it stinking HOT! then use some shock treatment ..... (ie) hammer on the end of the ball joint bed spanner
Carl S
Member #: 1761
Stalker
Ok, thanks for the advice Steve. I'll source a blow lamp from somewhere.
chinlesswonder
Member #: 1192
In the garage......again!!
try using a long breaker bar or if its a decent ratchet, a pipe over the handle to give more leverage. They can be tough but they should move
133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
Shakespear RWYB 14.995 91.83mph
Carl S
Member #: 1761
Stalker
i'm currently using a torque wrench with the torque setting up high as it's the only half inch drive ratchet i have. It's a decent quality one and is about a foot long (there abouts) so has reasonable leverage.
DON'T USE A TORQUE WRENCH!!!! it'll never work again; go get a decent breaker bar
As Steve said, get some heat into it; ideally, strip it off and get it in a vice though - it'll make it much easier puting the new one on.
Carl S
Member #: 1761
Stalker
Oh, looks like i'll have to leave the torque wrench alone then! I'm still a bit of a novice so I wasn't sure whether it would harm the wrench or not.
If the worst comes to the worst, I will remove the hub all together but i would like to avoid that if I can.
you should be able to get a decent breaker bar from the likes of Halfords for the job - not sure how much but money well spent in my opinion as you'll get a fair bit of use from it
chinlesswonder
Member #: 1192
http://cgi.ebay.co.uk/US-Pro-24-Power-Brea...%3A3%7C294%3A50
looks like it could more than handle most mini jobs and doesn't cost a fortune like some.
I remove my hubs and stuck them in a vice. Makes the job a whole lot easier.
Also, as above, get some heat into it.
There is a special single hex totally flat "flogging" spanner for this job (and also stubborn flywheel bolts).
I don't think they've been made for years but I have seen them come up on eBay occassionaly. (I've had mine for decades...)
Because they are flat, you can give them a really hard clout to free the threads off without any risk of it jumping off the hexagon.
EDIT - jjust looked, there's one there now
http://cgi.ebay.co.uk/Mini-Flywheel-and-Ba...93%3A1|294%3A50
Edited by Rod S on 21st May, 2009.
graemec
Member #: 1424
Carnforth, Lancs
MiniSpares sell them at half that price:
http://www.minispares.com/Product.aspx?ty=...&title=FLYWHEEL FLAT SPANNER 1.5...
Amazing - I didn't think they were even made any more.
Anyway, they are great on tight ball joints.....
Carl S
Member #: 1761
Stalker
That does look rather good, I may well pick that up. Cheers Rod, and Greame for finding a cheaper alternative!
