Home > Help Needed / General Tech Chat > electircal problems - windscreen wipers.
pot_dan
Member #: 326
bradford, west yorks
i have searched and found some almost usefulll info from jimster, but still no luck..
the car has been parked up for 5 months, now all back together and ready for summer, taxed and insured from tomorrow but the wipers refuse to work!
I have done a few checks, tried a different motor and so on. there is power getting to the motor and the earth, i believe to be good. After the 5 wires into the plug (on the motor) is 3 wires into the motor, if i move the wiper stalk, the power moves between the red and yellow wires into the motor, does it need both or just one of them?
I dont understand how the parking thing works, i dont even know where the switch is, if thats what it is. lol. But i do know that back when it was running before the wipers never parked them selves. they would stop where i stopped them. And i never had a problem with this.
Also, if i put the multi meter on the terminal it shows 12v then if i plug the motor in the voltage drops to 0 but the motor doesent even try to turn.
Please please give me some help or pointers, I dont want to be stranded in the rain *frown*
Thanks. Dan
Edited by pot_dan on 22nd May, 2009.
stefaz
Member #: 1656
stoke-on-trent
might sound daft, have you checked the earths?
pot_dan
Member #: 326
the earth from the plug works, but i am not sure how to test exactly how good, but i tried it with another earth of my own and that dident worth iether..
pot_dan
Member #: 326
just to let people know. i found the problem, the fuse had some corosion witch is why it was showing 12v on the meter then 0 when something actually tried to draw a real current. you live and learn... i did check the fuse but only to see it was in one piece. lol
thanks anyways stefaz!
Dan - now back on the road *happy* *happy* *happy*
Carl S
Member #: 1761
Stalker
Had exactly the same problem with my fog lamp fuse, pain in the arse to discover the problem aint it!
stefaz
Member #: 1656
stoke-on-trent
at least it was a simple fix mate. glad you're back on the road
did you ever figure out how the park thing works?
pot_dan
Member #: 326
No Brett I just stop them where I want. It's low on the priority list tbh but one day I might have a look.
