| Home > General Chat > Kirkey seats | |||||||
301 Posts Member #: 2480 Senior Member Swindon |
22nd May, 2009 at 10:02:53am
Hi all
feature=mhum |
1425 Posts Member #: 690 Post Whore Norfolk |
22nd May, 2009 at 11:18:34am
I've got a lightweight sprint deluxe, my only comment is that it can dig in under the arms - I'm 5 ft 9, so if you are talelr alls good, if shorter may be a problem!
If Carling made Mini engines
22nd May, 2009 at 11:34:52am
WHat are these like on the road?? Horrid?? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
22nd May, 2009 at 11:51:45am
They dont seem very comfortable but i think my excssive weight in each arse cheek should help!! feature=mhum |
22nd May, 2009 at 12:30:10pm
I'd rather sit on the floor pan with no seat and slide about the crossmember than sit in them!
458 Posts Member #: 1840 Senior Member Kings Lynn, Norfolk |
22nd May, 2009 at 06:08:28pm
Until you've sat in one they look terrible, but they're actually really comfy with support in all the right places.
22nd May, 2009 at 09:14:24pm
Yip - they are a lot more comfortable than they look and are much much stiffer than a composite seat of the same weight - I know which one I'd rather be in! If Carling made Mini engines
26th May, 2009 at 11:45:04am
Can these be fitted to the cross beam or do they need to be fitted behind it? What mounts would be best? I'm guessing they wont fit to my cobra mounts i already have? feature=mhum |
26th May, 2009 at 12:19:32pm
I've fitted the front of the seat to the rear of the cross member - if that makes sense, then made mounts to pick up off the inner sill and exh tunnel, its all custom stuff for these seats in a mini.
