Home > Help Needed / General Tech Chat > 1275 turbo wont run right
lasvegasturbo
Member #: 6204
got it to runn with regular carb so its not the engine i put the turbo back on it and it will start but it dies soon i havent checked any thing yet what is a good place to start thanks*surprised*
PaulH
Member #: 2340
Dublin Ireland
by taking a Breath
On 17th Feb, 2009 Rob H said:
miniboo
Member #: 2253
Las Vegas, Brit in the States
where abouts are you?
miniboo
Member #: 2253
I can come and have a look, not worked on a turbo mini before but 2 heads are better than one.
Check the plumbing as per this thread...
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=6298
lasvegasturbo
Member #: 6204
i took it apart again found that had a really bad exast leak dropped and cracked broke the neck off the plenum chamber so had to put the stock one on there checked that thread thanks the plumbing was all correct i going to check the regulator this week some time it sucks being in the us sometimes its expensive to get turbo parts here i will let u know how its coming
lasvegasturbo
Member #: 6204
i live on the north side of town about 30 minutes from nellis
giallofly
Member #: 164
The Stig..
Newport Pagnell
Is it flooding due to the vlave not shutting in the float chamber. You have to get the carb off to check that one.
They often stick open causing bad running.
Does it rev up or just die, give us some more details.
JF.
miniboo
Member #: 2253
MIght be able to come over next weekend if you want. I am in Hawaii at the moment though!!!
