Home > Help Needed / General Tech Chat > clutch drag when hot
turbo hogster
Member #: 178
stowmaket suffolk
well after getting the clutch to feel right i now have issues when she gets hot after a good burn, the plate i think is dragging of the flywheel so must be when the primary gear gets hot its sticking to the splines on the plate.
i cant remember if i put a smear of copper slip on there or not when i changed it.
so just asking what other peeps on here use on there splines for the plate
PaulH
Member #: 2340
Dublin Ireland
I have always Put them on dry in fact I always wash the Primary with solvent to make sure there is no oils on it.
IMO oil here is just somthing for clutch dust ot stick to
On 17th Feb, 2009 Rob H said:
As above, completely degreased and dry.
For the same reasons (just like an inertia starter bendix scroll, also for the same reason).
sound like idler endfloat too tight to me,
carl
chinlesswonder
Member #: 1192
In the garage......again!!
could be the primary gear sticking to the crank when its hot
133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
Shakespear RWYB 14.995 91.83mph
Not a defective slave is it? not giving enough travel after its been toasted by the turbo? thinking easy things first!
turbo hogster
Member #: 178
stowmaket suffolk
cheers for the input, primary had correct enfloat when installed, however i didnt clean up the splines, i used to use the red grease with clutch plates on the splines.
clutch movement is spot on its just dragging but to be honest it can wait untill winter unless its get worse as i need new drops any how.
I've got a defective slave....
the washing is piling up....
shane
Member #: 1246
Lowestoft, Suffolk.
PMSFL!!!!
