Home > Technical Chat > Stopping her blowing up
Zeemax Power
Member #: 393
Oulton Park
Alright lads my standard 1275 engine is having a metro turbo put on but what i need to know is can you buy a special pipe that will link my oil cooler hose to the block aswell as going to the turbo or do i have to get a metro one or make it? and with having a standard engine will the turbo blow it up like i mean will i have to change the compression ratios or put a steal head gasget on to slove that??
And could i put a bigger head on my standard block and pistons or would it blow
ITS A MINI ADVENTURE
http://www.Zeemax.com
evolotion
Member #: 83
Glasgow, Scotland
Do a search and read lo ts, the answers to your questions are lurkign on the forum..
you cant plumb the turbo in the takeoff for an oil cooler btw as this oil is u n-filtered and full of gearbox swarf . Check the for sale section for some pukka oil feed pipes etc :)
Denis O'Brien.
Zeemax Power
Member #: 393
Oulton Park
I'm not to assed about getting the pipes. It's more of a case how the pipe breaks off and goes to the turbo. I've got a pipe but i'm not sure how to plum it in its got two round hoops on each end and i can't work out how the oil cooler hose goes into it? And i can't find anything about putting a bigger head on a standard block. It's got to be either a yes or no
What do you mean by "Putting a bigger head on" ?. All 1275 engine heads are based on the same casting {12G940}, so you can modify the one you already have, with bigger valves, port work etc.
Phil. *smiley*
Zeemax Power
Member #: 393
Oulton Park
Yeah sorry mate i wrote it a bit wrong. I was wondering if you could do that but will it corse the head to blow or melt the pistons. I was just wondering if i could do it now i'vr got the engone out with doing a total strip down
And how much boost will a standard block take with blowing the head?????
There is no such thing as a "yes or no" answer to the questions you are asking. The best way to learn about the subject of putting a metro turbo engine in a mini is to do some research and read up, there are loads of previous threads in this forum that cover everything from water injection, to different turbos, to building an engine.
As for your turbo feed pipe, it does not attach to the oil cooler outlets. On the metro it is connected to where your oil pressure light switch is on the front of the block below the oil cooler take off point. It uses a special banjo bolt that you will need to get hold of to use the std pipe. The by far easier way is to get hold of the aftermarket braided pipe kit that is easily available from numerous mini spares suppliers, e.g. Avonbar, Minispeed, MED etc., as already recommended by someone else in this thread.
Zeemax Power
Member #: 393
Oulton Park
Thanx a hole lot Tom, just dieing to get the engine back in cos i need the car soon and i was just scared of blowing her up so i needed to know.
It was a 1.3i and cos i've converted it to carb i've got loads of wires that are no good and need chucking but i don't want to chuck what i need i know that i can get rid of the ecu but need to keep the eletrionic fuel pump in the tank do have to start again all wireing again? or do you know which wire it is and do i need to keep the box sitting on top brake servo and is the pump poweriful or do i need to get a metro one
