Home > Help Needed / General Tech Chat > How to wire it??? 3 pin distributor
paneermeel
Member #: 1404
The Netherlands
Hi you all:)
Bought a turbo distrubitor but don't know where the wires go to. I now got a 1000cc with breaker points. Dont know if i need to make a modification to the loom of just getting the right wire to the right pin.
All help appreciated
Piccie*happy*
Edited by paneermeel on 1st Jun, 2009.
there is nothing wrong with a A-series that a turbo can't fix.
www.turbomini.nl
paneermeel
Member #: 1404
The Netherlands
maybe this is better*happy*
Edited by paneermeel on 2nd Jun, 2009.
www.turbomini.nl
shane
Member #: 1246
Lowestoft, Suffolk.
Use the two outside of the 3 pins to connect to the ignition coil + -, I believe the engine will only run with it connected one way. SOmeone please correct me if im wrong.
Shane
tadge44
Member #: 2500
Buckinghamshire
Connect it with the wrong polarity and its toast.
paneermeel
Member #: 1404
The Netherlands
mmmm that gives me 50% to get it right. That's not enough for me. *Sick* Can someone verify what shane or tadge44 believe.
Thanx *happy*
www.turbomini.nl
tadge44
Member #: 2500
Buckinghamshire
Has the ignition amplifier got two or three pins ?.
If it has two, use the search button and you will soon find the answer - its good practice anyway for when you need answers on lots of probs.
If its a three pin amplifier maybe someone will tell me how to wire one as I bought one, having been assured I could use it on a two pin system,but there were no helpful instructions and it lies on the shelf.
I have the wiring diagrams for the two pin type but not the three pin type.
I'm 95% certain that Shane is right in that only the outer two are used on a three pin type.
I'm 100% certain that Tadge is correct in that if you connect it the wrong way around, it's toast.
Although I hate to suggest it, also try searching on MF and TMF, I'm sure I've seen the diagram on one of them...
I just posted out the connector for a late ellectronic dizzy. 3 connectors in the wiring block, but only the outside ones had a wire connected.
tadge44
Member #: 2500
Buckinghamshire
But do you know where these wires went - and what polarity ?
no, but I have a metro haines manual that I can have a look in tonight.
paneermeel
Member #: 1404
The Netherlands
changed the topic name for a more effective search in the future.
I could not find the info.
@apbellamy: that would be great
www.turbomini.nl
Well... Haines manuals are rubbish for wiring diagrams. Excluding plug leads, all models have two wires except for the late ones which have none....
Our metrovan is sat in my garage, I'll try and have a look at the plug tomorrow and see what's what.
