Home > General Chat > Renault 21 intercooler
1293 sprite
Member #: 5449
Melton Mowbray
Picked up a renault 21 intercooler off ebay tonight, looked in good nic in the pics, and seems a good shape for a mini.
Has anyone tried one of these before? or any pics?
James.
Edited by 1293 sprite on 31st May, 2009.
1293 88.8hp 82.2ftlb
17.3 1/4 @ 78 mph
Naturally Aspirated (for now)
shane
Member #: 1246
Lowestoft, Suffolk.
Have you any pics? One of our apprentices a few years ago had a 21 turbo he was running an Ic which looked very similar to a 5gt one?
Shane
1293 sprite
Member #: 5449
Melton Mowbray
no pics yet, its not been delivered yet. It was similar to the sierra cosworth one, long and thin. He had a few measurements on the advert, 600mm long 110mm deep and 70mm tall. I'll post some pics when it arrives early next week.
17.3 1/4 @ 78 mph
i think the 21 used the same ic as the espace tdi, the inlet ports are not both strait like the r5 one is
I was looking at this for the metrovan, but decided to just go with R5 as the inlets are both at the top on the R5 one.
nutter driver
Member #: 47
Not very sunny swanage
the 21turbos had two intercoolers as standard, so both people above are correct, they have one which looks simmilar to the 5 turbo one, and one which is similar to but smaller than a cossie cooler...... why they used twoand not just use one decent size one i don't know, its not like they were that tight for space?!?!?!
What nutter said...they normally had 2.
Coupe
Member #: 2178
Leyland, Lancs
I used one for most of last year, running 17 PSi boost, didn't have any trouble. Outlet side was always cold after running the car in anger, but now I'm switching to a 4wd cossie cooler.
shane
Member #: 1246
Lowestoft, Suffolk.
After some more thought I did wonder this, thanks, its been playin on my mind for days.
Shane
1293 sprite
Member #: 5449
Melton Mowbray
the cooler arrived today, so I'm off to take some pics and give it a quick clean. Coupe were you using the cossie like or R5 like cooler?
Shane, thats probably just renault for you!
Thanks all :)
17.3 1/4 @ 78 mph
Coupe
Member #: 2178
Leyland, Lancs
I was using the long cossie type cooler - although it is significantly smaller than a cossie cooler.
1293 sprite
Member #: 5449
Melton Mowbray
Ok, thats good to hear, thanks.
I've cut up the saab hard pipe i've got for the bends to route it around the servo, so it doesnt look too hard to fit/mount. I will put up some pics, i've just been a bit short of time recently.
17.3 1/4 @ 78 mph
1293 sprite
Member #: 5449
Melton Mowbray
Here is a few pics as it arrived the other day. Also gave it a quick clean.
17.3 1/4 @ 78 mph
shane
Member #: 1246
Lowestoft, Suffolk.
That looks a nice usefull cooler.
Shane
1293 sprite
Member #: 5449
Melton Mowbray
Thanks, I'm sure I'll find a good use for it *wink*
17.3 1/4 @ 78 mph
