| Home > Help Needed / General Tech Chat > tim fuel gauge problems | |||||||
" alt="User Avatar" width="100" height="100">52 Posts Member #: 1735 Advanced Member morton, lincolnshire |
31st May, 2009 at 10:42:07pm
hi guys got a problem with the fuel gauge. its a tim gauge ive wired it up but instead of going up to full it goes backwards way past the empty any ideas would be appreciated thanks |
![]() 1252 Posts Member #: 1656 Post Whore stoke-on-trent |
31st May, 2009 at 11:05:33pm
wires wrong way round?? On 23rd Oct, 2009 sim_ou_nao said:
eu gosto de mamas = i like boobs |
1st Jun, 2009 at 07:07:10pm
tried that one still doesnt work right, do i need a new sender do you think? for the tim gauge |
![]() 2102 Posts Member #: 432 Post Whore Swindon |
1st Jun, 2009 at 07:33:49pm
thinking outside the box, can you try another gauge? is the faceplate of the gauge put on in the correct place? |
1st Jun, 2009 at 08:48:27pm
the gauge is brand new, and ive tried the original gauge thats with the speedo and temp and that dont work at all but thats down to not having the voltage stabiliser on it, maybe i should try wiring up the stabiliser? |
![]() 460 Posts Member #: 843 Senior Member Stoke-on-Trent. Duck. |
2nd Jun, 2009 at 11:56:49pm
I put in a new Smiths gauge that ended up needing a new sender. It's a bit of a pain to drag out the tank and drill holes in it, but seemed to be my only option.
3rd Jun, 2009 at 10:58:44pm
Did the sender unit come with the gauge ? 9.85 @ 145mph
4th Jun, 2009 at 12:30:25am
Hmm, no. Unfortunately not - I think it cast me another £20 or so from Demon Tweeks. Then involved removing the petrol tank and drilling a big hole in the top! Not as scary as it sounds actually. |
4th Jun, 2009 at 09:52:56pm
ummm sounds a bit to much for me to do, i dont think i am comfortable messing around with the fuel tank might have to revert back to the original fuel gauge for now. thanks for your help guys |
