| Home > Help Needed / General Tech Chat > Cams and roller rockers | |||||||
![]() 115 Posts Member #: 2240 Advanced Member Co.Cavan....Ireland |
2nd Jun, 2009 at 09:35:17pm
Can somebody tell me what would be the best cam and what would be the best roller rockers to use on my metro turbo engine for my mini? Bending the rules and ruling the bends,Since 1959 |
2nd Jun, 2009 at 09:47:32pm
use the search button On 11th Feb, 2015 robert said:
2nd Jun, 2009 at 09:51:17pm
An A Series cam.
Edited by Rob H on 2nd Jun, 2009. Isambard Kingdom Brunel said:
2nd Jun, 2009 at 10:01:18pm
Well i want more power.Ive had the block bored out to a 1305 and the head is being polished and ported at the moment,So id like to kno what cam and roller rocker to fit? Bending the rules and ruling the bends,Since 1959 |
2nd Jun, 2009 at 10:17:27pm
a narrow plan of your engine spec if you dont mind me saying......anyway the cam i suggest to you would be the kent 266 cam or the mg metro normally aspirated cam.
2nd Jun, 2009 at 10:48:01pm
I had a look and coundnt find anything to say which would be the best roller rockers.And as for the cams,Im new to all this and dont know much about them? Bending the rules and ruling the bends,Since 1959 |
![]() 1733 Posts Member #: 1910 Post Whore Wilts |
2nd Jun, 2009 at 11:10:42pm
If you dont already have one, invest in the big yellow bible, you'll learn shed loads!
the pissed up clown stood back up, did a twirl and left bollock naked, |
3rd Jun, 2009 at 07:55:54am
i would go for 1.3 roller tip rockers rather than 1.5's you wont lose much if anything in the power stakes but its far nicer to the cam and followers plus oil pump always looking for them bigger bunches of bannanas |
3rd Jun, 2009 at 06:10:20pm
Well its a start. Bending the rules and ruling the bends,Since 1959 |
4th Jun, 2009 at 12:20:17pm
Please correct the following if it is wrong.
Own the day
4th Jun, 2009 at 07:44:12pm
Yeah that helps abit.Im still a novice to this and all words of wisdom are welcome. Bending the rules and ruling the bends,Since 1959 |
4th Jun, 2009 at 10:30:53pm
Given you're a novice...
Edited by stevieturbo on 4th Jun, 2009. 9.85 @ 145mph
4th Jun, 2009 at 10:41:43pm
I have my mechanic doing all the work on the engine and yeah he knows what hes at.Im gettin the engine rebuilt so i want to do all this sort of work when its been put back together. Bending the rules and ruling the bends,Since 1959 |
6th Jun, 2009 at 07:29:53pm
Would a avonbar phase 2 turbo cam work well with 1.5.1 roller rockers? Bending the rules and ruling the bends,Since 1959 |
6th Jun, 2009 at 07:36:08pm
The Phase 2 is a great cam, Avonbar recommend to use it with 1.3 ratio rockers, though I've used it with 1.5's, you may lose a little bottom end power. |
6th Jun, 2009 at 07:38:45pm
Thanks for the advise phil. Bending the rules and ruling the bends,Since 1959 |
