Home > Help Needed / General Tech Chat > Compression Ratio???
paul1986
Member #: 6234
Retard & Spaz
Yeovil, Zummerset
hi all
i have started to put together my turbo engine only to find out that ontop the pistons there are marking saying +0.30 so i am assuming i have a overbore engine, so firstly is this a 1310?
secondly i do not have a clue how to work out my compression i have tried searching over and over again and it still confuses me lol so any help would be great, the engine spec as far as i can see is:
12g940 head possilbly skimmed as this measures 69.30mm
Engine bore of well maybe 1310 ( measures about 71.35mm )
dished pistons of 7mm
and a stroke of 78mm
i hope this sounds right, oh and its currently a n/a engine with std valves.
please help guys what is my compression ratio????*frown*
Currently building the new engine - 1312 t25 a series!
Mr Joshua
Member #: 1954
Luton Bedfordshire
Deck to piston height?
Head gasket being used?
Decompression plate fitted if so what size?
piston cc?
Combustion chamber volume?
Own the day
CR#
Member #: 1367
Cape Town, South Africa
Its as simple as the volume in the combustion chamber at the bottom of the pistons stroke over/divided by the volume at tdc.
Here are two calculaters after a quick search on google.
http://www.csgnetwork.com/compcalc.html
http://www.rbracing-rsr.com/compstaticcalc.html
Greg
Edited by CR# on 3rd Jun, 2009.
paul1986
Member #: 6234
Retard & Spaz
Yeovil, Zummerset
deck to piston height is approx 4mm, i will use a std metty turbo head gasket, no decompression plate, piston cc unsure combustion chamber volume unsure
CR#
Member #: 1367
well thats all stuff you will need to work out before you can calculate your CR.
gl
paul1986
Member #: 6234
Retard & Spaz
Yeovil, Zummerset
lol ok sounds like fun, i am sure its easy really
paul1986
Member #: 6234
Retard & Spaz
Yeovil, Zummerset
i think i may have worked this out right piston cc would be 11 skimmed head means 22cc cambers yeah? gasket i have been told will be 3 in the equation so i come up with 37? so 37-327= 8.8 does this look right? like i said i think piston cc is 11 if my maths are right 1310 so +30 overbore and 7mm dish?
You need to measure the chamber volume in the head properly. They are supposed to be 21,4cc as standard, but they can vary quite a lot from the factory.
Mr Joshua
Member #: 1954
Luton Bedfordshire
without knowing who made the pistons you will have to measure the cc the old fashioned way no point in guessing *wink*
Own the day
