| Home > Help Needed / General Tech Chat > Can i use a md 276 cam to my turbo project? | |||||||
3 Posts Member #: 402 Junior Member |
9th Nov, 2004 at 08:23:59pm
Kent 276 in a turbo engine? Tobias |
421 Posts Member #: 245 Senior Member |
9th Nov, 2004 at 10:40:36pm
use a phase 2 cam (piper) |
9th Nov, 2004 at 11:04:09pm
It will work, and probably quite well... Will prob have a better tickover than the ph2 aswell... On 17th Nov, 2014 Tom Fenton said:
591 Posts Member #: 360 Stu from Corwall aka Mr Jazz Piano, Love_Machine, kneegrow |
10th Nov, 2004 at 12:55:04am
Why, Dave?
Bugger off, I'm getting there. |
10th Nov, 2004 at 07:41:34am
Ive got a ph2 in dave and the idle is rock steady and very even. suprised me. running stock rockers though which will probably make a difference. |
![]() 4641 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
10th Nov, 2004 at 08:45:00am
My idle was always smooth with P2 and 1.5 rockers fitted.
10th Nov, 2004 at 06:49:11pm
Maybe i've got a bad grind!!!! For me, Idle is 900rpm. At 900rpm and 1.5 rockers, my ph2 idle is far from steady. LOL!!! It used to be just acceptable with the 1.25's mind.
10th Nov, 2004 at 06:53:32pm
I run a 276 timed in at 110deg. Seems to work very well, it is a 1380 however!! As for an oil pump i like the avonbar one, pricy but does a bloddy good job. -MINI CLUBMAN 1380 TURBO- |
10th Nov, 2004 at 08:15:39pm
http://www.pistonheads.com/gassing/topic.a...124140&f=66&h=0
10th Nov, 2004 at 09:29:08pm
If referring to pg4 - I don't know or agree with that Stevie guy all/most of the time - but he claims to have tried a series of different cams and found best effect with the milder ones...
![]() 243 Posts Member #: 89 Senior Member Sydney Australia |
10th Nov, 2004 at 10:39:03pm
i hav eno got really confused after seeing my cam figures from my dial indicator mine is stuffed, i was going to go to a avonbar Ph2 now i have seen there is a piper ph2.
179hp on 12psi 1293cc of pure A series
11th Nov, 2004 at 12:01:42pm
I have decided to go with the Ph 2 as it is pretty much a 266 with longer exhaust timing and a tad shorter inlet. Not very much overlap. From what I can gather, it seems like the wisest choice. As the 276 causes rougher running in N/A engines, I would attribute this to the overlap. A 266 would be a good choice but it doesn't have enough exhaust (IMO). As they say, a supercharger loses its efficiency at high revs and this is especially true with the Bini Blower. So, something which tops out at about 6500 would be nice. That seems to point a big finger at the Ph2. Will try an old Auto cam I have kicking around. 232/240 I think.
