| Home > General Chat > Would this fit?? Another one of my daft questions... | |||||||
3rd Jun, 2009 at 09:35:57pm
3rd Jun, 2009 at 09:56:44pm
As they say; there's only one way to find out. Isambard Kingdom Brunel said:
3rd Jun, 2009 at 10:35:58pm
Order a swift head gasket and try it over the top of an a-series engine. If something is worth doing, it's worth doing half of. |
Forum Mod ![]() 1927 Posts Member #: 1761 Stalker Bristol |
3rd Jun, 2009 at 10:53:04pm
Unless you can reverse the head, I think the cam wheels are on the wrong side. |
4th Jun, 2009 at 09:33:07am
It looks the 'right way round', I'd order a gasket and see how close it matches up. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
4th Jun, 2009 at 10:02:02am
Was just an idea...
4th Jun, 2009 at 10:51:01am
being 1400 and modern engines are over square, the bore will be bigger than 74mm, so no, by by reasoning, it wont fit On 26th Oct, 2004 TurboDave16v said:
1391 Posts Member #: 1686 Post Whore Oxford |
4th Jun, 2009 at 10:54:38am
78mm :( On 19th Feb, 2011 Miniwilliams said:
OMG Robert that's a big one |
4th Jun, 2009 at 11:01:31am
Hold on was this idea not in a thread not too long ago asking "does anyone recognise who this is" or something like that, where you saw the engine sat on the floor while it was run up!
Own the day
4th Jun, 2009 at 11:01:41am
Idealy you need to find an engine with no bigger than 71 mm bore, as they will have spaced the bores equally, and have a reasonable chunk of metal between them, unlike the A series. Anything bigger than 71mm and the alignemet goes all to fuck.
4th Jun, 2009 at 11:04:21am
On 4th Jun, 2009 Mr Joshua said:
Hold on was this idea not in a thread not too long ago asking "does anyone recognise who this is" or something like that, where you saw the engine sat on the floor while it was run up! The guy got rumbled because some eagle eyed user recognised his garden! On 11th Feb, 2015 robert said:
4th Jun, 2009 at 11:07:53am
Ahhhhhh (fade to silence). Own the day
4th Jun, 2009 at 11:34:15am
On 4th Jun, 2009 Sprocket said:
Idealy you need to find an engine with no bigger than 71 mm bore, as they will have spaced the bores equally, and have a reasonable chunk of metal between them, unlike the A series. Anything bigger than 71mm and the alignemet goes all to fuck. Rule of thumb, look for something with 76mm ish bore centers and it will work On 11th Feb, 2015 robert said:
4th Jun, 2009 at 10:21:12pm
Toyota Starlets run a small bore.....
![]() 514 Posts Member #: 2104 Post Whore Essex - UK |
12th Jun, 2009 at 11:05:39am
i have a mate with a starlet and spair gaskit do you want me to see if it lines up?
"Tuning should be a compromise between what is possible and what is necessary"
12th Jun, 2009 at 11:16:36am
Go for it!
On 12th Jun, 2009 turbominij said:
i have a mate with a starlet and spair gaskit do you want me to see if it lines up? on a block? i can post pic's If something is worth doing, it's worth doing half of. |
13th Jun, 2009 at 10:09:42am
