Home > Help Needed / General Tech Chat > Pot Joints
Mr Mini
Member #: 346
Portsmouth
Hello can anyone tell me whether the pot joints should be slid onto the diff output shafts with grease or anything at all? If it is grease what type should I use? Copper grease? Also is the pot joint the only require install to prevent the oil coming out of the diff?
Thanks.
1310cc TWINK - T Conversion
Don't really need anything, a light smear of engine oil won't hurt though.
There will be plenty of oil in there when you fill the engine up, so no need.
