| Home > Help Needed / General Tech Chat > O/T - Honda Integra Overfuelling? | |||||||
4th Jun, 2009 at 04:11:00pm
Off topic guys.
Edited by richminiturbo. on 13th Jun, 2009. |
4th Jun, 2009 at 04:15:51pm
do they run a twin sensor on the integra's? also what fuel is he using in it? not sure if it would happen but it could be overfueling as its running a lower octane than the ecu is used to (jap inport) Drives
4th Jun, 2009 at 05:51:12pm
Twin O2 sensor you mean? If so, i'm 90% sure they dont. Where would a second one be, after the cat?
Edited by richminiturbo. on 4th Jun, 2009. |
4th Jun, 2009 at 06:03:03pm
The ECU doesnt know the octane rating of the fuel being put in the tank, so it wouldnt be adjusting the fueling to deal with this.
4th Jun, 2009 at 06:12:10pm
60k on the clock.
4th Jun, 2009 at 06:38:51pm
De catted? AlexF |
4th Jun, 2009 at 06:43:45pm
Nope its got a cat and the mecanic mentioned this was in tip top condition. |
4th Jun, 2009 at 07:19:01pm
they do run pretty rich up top tbo, and isnt uncommon for them to burn a bit of oil at full chat right up the rev's. do a leak down test :) turbo 16v k-series 11.9@118.9 :)
274 Posts Member #: 1174 Senior Member Sunny Southern California, USA |
10th Jun, 2009 at 06:14:17am
Valves or blow-by. High mileage B18 motors were notorious for burning oil, and spitting out black crap. 61 Austin Seven; building a 1275 'over the clutch' turbo, R5 T2'd, custom intercooled, megajolt electrified, canyon carver
204 Posts Member #: 5022 Senior Member Oxford, Kings Lynn, Pod, Pub. |
10th Jun, 2009 at 01:15:19pm
Hondas do run quite rich towards the redline standard, how many miles has the Cap/Rotor arm plugs done, as they could be worn causing a slight missfire up the top end which you may not feel. as above the B18s do tend to get a little oil thirsty after higer millages, the obvious sign of this is checking hte dipstick regularly, etc.
Got A GTM With A Honda In the Back, and huge Nitrous bottle where the passenger seat should be when racing!
On 19th Oct, 2009 Nic said:
Ill donate to the cause if you can make it do wheelies!! |
10th Jun, 2009 at 04:56:32pm
my high compression mpi does this.
13th Jun, 2009 at 07:15:21pm
Sorry guys I didnt realise there had been more replys!!
13th Jun, 2009 at 07:22:34pm
no but it pressurises the crankcase forcing oil out the breathers into the plenuiniarm :) Edited by evolotion on 13th Jun, 2009. turbo 16v k-series 11.9@118.9 :)
13th Jun, 2009 at 07:54:39pm
But surely blow by would cause running issues? What with compression being lower wouldnt it be noticeable even if on one cyl?
13th Jun, 2009 at 08:03:05pm
no no runnign issues, will just simply have blow by / burn oil at high rev's they all do it onc ethe mileage starts to get up, its a common thing, either keep the oil level checked or rebuild :) turbo 16v k-series 11.9@118.9 :)
13th Jun, 2009 at 08:17:11pm
Cool cheers Denis :) |
