| Home > Help Needed / General Tech Chat > Correct MegaJolt? | |||||||
21 Posts Member #: 6195 Member |
4th Jun, 2009 at 06:42:42pm
hey peeps,
4th Jun, 2009 at 07:08:41pm
Yep that's the right one. Sounds like it has most of the parts to install it too.
499 Posts Member #: 2257 Senior Member Brighton |
4th Jun, 2009 at 07:10:05pm
Looks like the right sort. MAP for turbo use plus the EDIS and sensor. You ll just need to fabricate a sensor mount. |
6th Jun, 2009 at 08:29:57am
looks like most things are there, the mole connector? is not there, and could not see the vr sensor, all are easy to get. and as above you need a bracket which you could get from tom.
6th Jun, 2009 at 10:53:16pm
just looking at this
133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
8th Jun, 2009 at 12:04:33pm
yea running a 1275 Turbo std, other than lucas coil,bailey dump valve. nice plugs, bosch.
8th Jun, 2009 at 01:34:15pm
anotherthing. lol.
8th Jun, 2009 at 01:46:47pm
just got a reply from the seller, i asked him if there was a crank sensor and if the molex plug was wired up already this is reply,
8th Jun, 2009 at 07:55:08pm
no reason why not, you can buy the mole connector separately and buy a vr sensor from most scrap yard |
