| Home > Help Needed / General Tech Chat > Engine Down on Power (Or is it?) | |||||||
329 Posts Member #: 3193 Senior Member Torbay, Devon |
4th Jun, 2009 at 09:21:32pm
4th Jun, 2009 at 09:29:35pm
Compression ratio is what??
4th Jun, 2009 at 09:37:50pm
4th Jun, 2009 at 09:39:08pm
i think the manifold and head will be your limiting factors personally.
Edited by Nick on 4th Jun, 2009. On 20th Oct, 2015 Tom Fenton said:
4th Jun, 2009 at 10:26:36pm
what size wheels you running? you could drop 10% power if your on 13x7 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
4th Jun, 2009 at 10:38:18pm
Compression ratio is the compression ratio, e.g. swept vol plus unswept vol divided by unswept vol. I'd guess it would want to be 10.5:1 or more to work with that cam.
![]() 465 Posts Member #: 1972 Senior Member Worcester |
5th Jun, 2009 at 08:59:54am
This spec should produce more power really.
Edited by retroracer1380 on 5th Jun, 2009. |
5th Jun, 2009 at 10:09:31am
I agree with the above.
5th Jun, 2009 at 10:16:00am
IMHO the most that spec will make at the wheels will be 70 which is + or- 90 at the flywheel. What RPM did it make your current figure at On 17th Feb, 2009 Rob H said:
5th Jun, 2009 at 10:45:35am
5th Jun, 2009 at 11:16:33am
I would be inclined to fit a 3 into 1 manifold with a 296 scatter cam. Everything is at the top end and that is where the 3 into 1 is best suited
5th Jun, 2009 at 11:24:24am
you have quite a veriety with the compression ratios you should try and get them all pritty much the same, i thought the turbo boys were runnning about 170ish psi possible headgasket failer? Drives
549 Posts Member #: 5327 Post Whore Dudley, West mids |
5th Jun, 2009 at 08:45:14pm
I got 112bhp out of my 1330. Basically the same spec as yours except I had a minispeed stage 3 head. I was running a hif44 with no problems. What fuel pump are you running??? Is it up to the job? |
5th Jun, 2009 at 09:07:11pm
I am running the standard mechanical fuel pump.
6th Jun, 2009 at 12:00:46am
this wont help really, get a red top pump on there! search for compression and have a read! Then speak to one of the lads about getting your head done 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
6th Jun, 2009 at 12:10:32am
If the engine doesn't run lean at any time, I guess the fuel pump is OK. On 13th Jul, 2012 Ben H said:
6th Jun, 2009 at 08:27:27am
You will still be ok with a mechanical pump at this spec i used to run one at 85horse on an old 1380 with 286 and no probs.
