| Home > Help Needed / General Tech Chat > drop gears noise | |||||||
54 Posts Member #: 64 Advanced Member |
29th Sep, 2003 at 12:57:44am
Hi everyone, |
30th Sep, 2003 at 12:18:07pm
Could it be your clutch release bearings? |
1st Oct, 2003 at 06:01:47am
Sounds like typical drop gears to me. I usually set the idler gear and primary clearance as tight as possible (factory minimum clearance) and this makes them silent. They will be noisy if the clearance is close to factory upper limit.
1st Oct, 2003 at 10:37:52pm
I think that the problem is in radial play on primary gear. It has at least 0.5 mm of play so it defenetly needs new bushes. What do you think about floating front bush? |
2nd Oct, 2003 at 09:44:43am
0.5mm radial is quite a lot!!!
2nd Oct, 2003 at 10:01:05am
Well that explains the noise. There is no point in fitting one with that kind of play. It only wears the axial thrusts within a few hundred kms if even less ! With bad luck you?ll end up looking for another crank...
3rd Oct, 2003 at 11:37:54am
Yes I know that there is no point in fiting one with that kind of play, but I thougt...maybe it will be OK... I |
6th Oct, 2003 at 06:33:34am
All floating bushes that I have seen so far (not Mini primary gear but in general) are one piece, not split. I don?t know how the Minispares item looks like but it would sound logical that it is one piece. Dave ??? |
6th Oct, 2003 at 06:48:53am
I agree with you Jukka, but I like to ask before doing semething like that, just to be shore...
, my mistake. I know that on this kind of engine helical drop gears (their bearings, maybe better to tell) are overstresed and have short life when fitted new, not to thell what would happen with this one if I have drove the car with them. Since I live in Croatia it is rather hard to get any part for mini. I allready have new rear hat type bush but I don't have front one. Regarding all that I have decided to fabricate my own floating front bush (from phosphorus bronce). What should I keep in mind, does it need to have cut (like the one on minispares site) or it can be all in one piece like ring? Any help welcome...
