Home > Technical Chat > sump guard
Mickey.h
Member #: 2240
Co.Cavan....Ireland
Does anybody have the dimensions of a sump guard as i would like to make my own?*tongue*
Bending the rules and ruling the bends,Since 1959
Anyone on here run a sump gaurd? I think they would weigh too much *hehe!*
I'll measure mine this evening.
I brought one for the BOC when it was my daily drive as the speed bumps at work are bloody aggressive and they'd worn down part of my gearbox housing.
Mickey.h
Member #: 2240
Co.Cavan....Ireland
Thanks rob
Here we go:
20 inches
1 1/2 inches
1 1/4 inches
A smidgen under 2" between each of the seven holes
4" between the holes centers & the deck
15 1/2" inches long
Mickey.h
Member #: 2240
Co.Cavan....Ireland
Cheers rob.Thanks very much*happy**happy**happy**happy**happy*
MattyC113
Member #: 10248
Hertfordshire
This is very helpful thanks very much to both of you
i have a sump guard as i kind of need it....
dimensions same as above but mine extends quite far back
only bit of advise i can give... fit an oil temp gauge and seriously think about an oil cooler,
my mini was running 120-135degC @55mph without a cooler and now its in check
also mine is 10mm thick and i can jack from it ( after jacking it up to get a trolley jack under it *happy* )
Edited by Brett on 19th Jan, 2013.
