| Home > Help Needed / General Tech Chat > Engine Breathing???? | |||||||
549 Posts Member #: 5327 Post Whore Dudley, West mids |
6th Jun, 2009 at 08:13:40pm
Hi folks. I know that efficent engine breathing is needed in any engine, but I have just brought a belt cam drive conversion for my A+ turbo. The thing is that unlike the original cover there is no breather pipe fitting. Is using just one breather (Clutch side) on this own effective enough?? Many thanks. Gav |
6th Jun, 2009 at 08:21:00pm
my understanding is that A series engines need to breathe, the more breathers the better. |
6th Jun, 2009 at 08:26:23pm
6th Jun, 2009 at 08:27:48pm
Would one to the rocker cover be enough? |
6th Jun, 2009 at 08:56:05pm
If you are running megajolt you could use your dizzy hole for another breather. |
7th Jun, 2009 at 10:43:21am
I have 2x 1" tubes welded into the flywheel housing end of the rocker cover, one comes from the flywheel housing breather, the other goes to a catch tank (well lemonade bottle....)
7th Jun, 2009 at 11:14:57am
if you want a rocker cover with a breather on the top i have a spare if your interested |
