Home > Help Needed / General Tech Chat > harnesesssssss
Carl
Member #: 95
liverpool-on-sea
im in the middle of doing lots of welding to the mingy and need to think about how to do the rear harness mounting bolts obviously need to weld plates in etc but where is the best place to fix them i was thinking at the bottom of the rear bulkhead would this be ok. i could go to the top of the bukhead/parcel shelf area if need be but i dont think this area could take much force
any pics would be really appriciated *smiley*
Nick
Member #: 154
Midlands
i'm sure i saw somewhere that the harnesses shouldn't drop by more than 20 degrees from where they come over the seat. probably totally wrong though knowing me :)
Bottom of the rear seat back is fine. What year is your shell ? My shell had mounting points here already for rear seat belts, i just used these. The harnesses should be between 90 & 45 deg.
Phil.
*smiley*
Carl
Member #: 95
liverpool-on-sea
mine is a '93 shell and its got them rear seat belt mountins too i was just making sure i could use these as im replacing the rear bulkhead *smiley*
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
do a search... this topics been on here before :)
AlexF
mine are about halfway up the bulkhead with load spreaders *smiley*
going to tie them into a rear "strut brace" between the rear shocks.
Carl
Member #: 95
liverpool-on-sea
alex ive read that post and didnt really understand it(im a bit dumb)
iain i thought about that but thought the seat back might buckle with me tugging on it in a crash. will be ok with your strut bar though
