Home > Help Needed / General Tech Chat > MK1 Metty Turbo Rad.
lockfast
Member #: 2775
Aberdeen
I am planning on fitting one of the above rads to my project when I do my rebuild. I already have the rad but I dont have the fan switch that fits it. I have tried a couple of local factors and they both offer me one that doesnt fit. It would appear that I need some type of holder or similar for the switch that they both offer. The rad itself has two lugs at the end of where the swithc goes that looks like it would press in and twist. Can anyone help either with a part number or the part itself? Or can anyone shed some light on the part that might be missing
Cheers in advance
Kean
Member #: 341
aka T2clubby
South Staffs
I had the same issue with mine mate, I ended knocking one up out of a bit of steel.
Been in there 4 years and no issues.
Balls, gave mine away!
If its any help i know that they are the same on the SPI rads.
I've got a couple of metro rads knocking round. should have the bit your after.
Put up a pic of your switch enclosure bit to make sure mine is right. There are a couple of types, depending on whether it's afactory rad or not
