| Home > Help Needed / General Tech Chat > supercharger? | |||||||
![]() 871 Posts Member #: 2590 Post Whore Croydon |
8th Jun, 2009 at 05:41:46pm
does the supercharger need to be modified internal at all? |
869 Posts Member #: 2443 Post Whore Cheshire |
8th Jun, 2009 at 06:14:12pm
Depends what you intend to do with it and how your going to run it? If your going for the typical suckthrough config then nothing is needed just make sure you calc your pulley sizes andcorresponding boost pressures correctly |
8th Jun, 2009 at 07:19:45pm
i was going to run it like this
8th Jun, 2009 at 07:21:53pm
also i know with any mini it is typically easyier to take the engine out as there is not much room but. is it possible to fit a supercharger with engine in persisition.
38 Posts Member #: 4584 Member Perth, Australia |
9th Jun, 2009 at 11:42:58am
I'm planning this same conversion on my engine. Shouldn't be necessary to remove engine. The supercharger belt and pulley will be in the way of an ultimate engine steady. Jonspeed sell one to fit but is a bit expensive. You may want to start by fitting an oil temp gauge. Probably not necessary to fit an oil cooler. |
