| Home > General Chat > Fricken so called 'genuine' engine gasket sets!!!!!!! | |||||||
8th Jun, 2009 at 08:39:43pm
8th Jun, 2009 at 08:49:33pm
Man, i feel your pain!
8th Jun, 2009 at 08:57:18pm
On 8th Jun, 2009 Sprocket said:
While Im here, has anyone else noticed how much thicker the engine/ box gaskets are compared to what used to be the VERY original gaskets. Yes, Timing chain plate to block, requiring loads of extra shims behind the bottom sprocket (no pun). Transfer housing leaving to big a clearance on the idler, The worst one, diff output flanges to the extent I couldn't find enough shims to preload the carrier bearings correctly - I finally sourced a set of genuine Rover sideplate gaskets which were the required thin-ness. And now it turns out my BK450 (luckily not yet fitted) is also crap...... Schrödinger's cat - so which one am I ??? |
8th Jun, 2009 at 09:08:20pm
Cant you just buy from any Payen stockist, or dont they supply anymore ? 9.85 @ 145mph
8th Jun, 2009 at 09:30:10pm
http://uk.rs-online.com/web/search/searchB...oduct&R=0129123
![]() 1252 Posts Member #: 1656 Post Whore stoke-on-trent |
8th Jun, 2009 at 09:37:39pm
you've only gotta mess it up another 49 times colin On 23rd Oct, 2009 sim_ou_nao said:
eu gosto de mamas = i like boobs |
8th Jun, 2009 at 09:48:57pm
Sorry mate but I'll only be doing that the once On 26th Oct, 2004 TurboDave16v said:
8th Jun, 2009 at 11:49:52pm
Surely you've got a spare one left over somewhere............. |
8th Jun, 2009 at 11:57:07pm
8th Jun, 2009 at 11:57:24pm
sorry |
9th Jun, 2009 at 12:01:24am
Ok mate made me laugh :)
9th Jun, 2009 at 12:19:13am
We should all convert to the k series |
9th Jun, 2009 at 12:30:52am
On 9th Jun, 2009 Nic said:
We should all convert to the k series And suffer with shit head gaskets still, lol On 26th Oct, 2004 TurboDave16v said:
9th Jun, 2009 at 12:31:22am
myth |
9th Jun, 2009 at 12:32:48am
could well be
9th Jun, 2009 at 12:33:38am
9th Jun, 2009 at 12:33:52am
maybe
9th Jun, 2009 at 12:41:21am
Who manufactures an engine where the head bolts hold the sump on On 26th Oct, 2004 TurboDave16v said:
9th Jun, 2009 at 12:51:51am
http://www.youtube.com/watch?v=Os3b6hVOrFg On 26th Oct, 2004 TurboDave16v said:
9th Jun, 2009 at 07:52:41am
We should all convert to the k series And suffer with shit head gaskets still, lol Please keep up Sprox, that's a thing of the past. On 13th Jul, 2012 Ben H said:
9th Jun, 2009 at 11:47:59am
Sproket,
Edited by Mr Joshua on 9th Jun, 2009. Own the day
9th Jun, 2009 at 01:04:16pm
On 9th Jun, 2009 Mr Joshua said:
Sproket, if anyone has the dimensions for this seal I will look through our seal kits and stick one in the post with extreme haste! Or are the dimensios 3/4" x 1" by 1/8" the figures Irequire? As in the link. Thanks, but I went and bought a complete cheapo gasket set just for the O ring. Its the right size
The actual dimention of this O ring is 3.5mm thick, by aprox 19mm, by aprox 25mm. The closest British standard Oring is BS210N70 18.64 x 3.53 (IDxCross section) and are 12 pence each http://www.polymax.co.uk/acatalog/NBR_O-Ri...01_-_BS284.html
9th Jun, 2009 at 01:35:28pm
Polymax is who I used to buy the O rings to build my injection manifold - strangley I nearly bought a bag of these (g'box to block) to make up the minimum order value, but opted instead for a bag of the size that goes at the base of a dizzy drive (another one never in the kits) as I didn't have a spare for my phase sensor.
9th Jun, 2009 at 02:45:45pm
Checked and we have stock but all's well in the end. Own the day
9th Jun, 2009 at 07:18:19pm
We should all convert to the k series And suffer with shit head gaskets still, lol 'roon ye. :) turbo 16v k-series 11.9@118.9 :)
