| Home > Help Needed / General Tech Chat > cruising issue | |||||||
![]() 71 Posts Member #: 2328 Advanced Member Nr Newmarket, Suffolk |
9th Jun, 2009 at 11:17:20am
100% BMW Free |
![]() 2102 Posts Member #: 432 Post Whore Swindon |
9th Jun, 2009 at 11:20:07am
i would say put it on the rollers |
9th Jun, 2009 at 12:09:39pm
There is a known problem with the transition from cruise to light acceleration with the SU in a turbo application.
9th Jun, 2009 at 02:28:05pm
I agree with Paul above, mine is exactly the same, chuggs a bit, but accelerates lovely, it feels like its got a big cam in making it cough, i put it down to air speed across the head with the large valve head i have. 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
9th Jun, 2009 at 03:23:46pm
I believe the last time this subject came up it was when the question was asked about the part throttle lean of pipe and the apparent massive flat spot it can cause when trying to accelerate gently.
Own the day
9th Jun, 2009 at 03:30:24pm
Thanks for the replies :)
On 9th Jun, 2009 Mr Joshua said:
Do you have this pipe still fitted. Its the pipe that runs from the front of the carb just infront of the dash pot to the left hand side of the carb just below the dash pot. Yes i have this pipe connected. Should i block both ends of it off? What do you suggest, Cheers, Guennie 100% BMW Free |
9th Jun, 2009 at 05:18:21pm
On 9th Jun, 2009 Paul S said:
There is a known problem with the transition from cruise to light acceleration with the SU in a turbo application. Turbo Tel covers it is this post: This thread as well as the one Paul has given a link to may be of help infact the one paul links to is mentioned in here as well http://www.turbominis.co.uk/forums/index.php?p=vt&tid=286255 Own the day
10th Jun, 2009 at 10:21:13am
On 9th Jun, 2009 Guennie said:
Thanks for the replies :) From what you've said it sounds like a fueling issue then. I'd like to have it rolling roaded as soon as i can, but as i said i'm still running it in at the moment! On 9th Jun, 2009 Mr Joshua said:
Do you have this pipe still fitted. Its the pipe that runs from the front of the carb just infront of the dash pot to the left hand side of the carb just below the dash pot. Yes i have this pipe connected. Should i block both ends of it off? What do you suggest, Cheers, Guennie I think it works ok on some engines, not so on others. I had to cut mine and block each end off. Might be worth a try see if it improves the drive, you can always connect it back easily. 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
10th Jun, 2009 at 02:31:19pm
I'll give this ago tonight and see what what happens.
100% BMW Free |
