Home > Help Needed / General Tech Chat > oooooooo lubrication!!!!!!
turbochargedstu
Member #: 908
gateshead
just wondered what oil people were using. any to steer clear of or recommend??
basic spec if it helps:- 1330, sc box, 17psi, roller rockers, vandervells, turbo pump.
balls to the blower!!!
eaton_mini
Member #: 1649
West Sussex - dreaming of forced induction!
I use Millars CTV 20/50 but mine is N/A
mushed up banana skins ,works for me,
You been watching fred dibnah?
Mr Joshua
Member #: 1954
Luton Bedfordshire
Muhahaha, lucky you never said lubricant. or else this thread would have gone into free fall *hehe!*
Halfords semi synthetic.
Here is an interesting bit of info my brother passed over. Apparently in the States its common practice to change oil every 3000 miles or less. One of the chaps he works with said the oil in his 56k motor comes out almost as clean when it went in.
Edited by Mr Joshua on 10th Jun, 2009.
Own the day
I make sure my oil is changed every 3000 miles, so mine is very well lubricated.
I use valvoline vr1 oil, but mines not a turbo.
tadge44
Member #: 2500
Buckinghamshire
As I only do a very limited mileage I change the oil twice a year which works out about 1500/2000 miles.Frequent oil changes are cheap insurance for your engine.
My regular transport is a turbodiesel and I change oil and filter every 5000.
The A series oil is only slightly discoloured but the diesel is black as sin, of course.
Turbo Shed
Member #: 30
Epsom, Surrey
i've used valvoline racing 20/50 for some years and recomend it, but this time i will be fitting millers as it sounds like its been developed for the mini.
turbochargedstu
Member #: 908
gateshead
hmmm. i recon millers should do the trick then!
i seem to remeber rally design does ctv at a reasonable price, (cant get it out here in the arse end of nowhere...)
shell rimula.
turbochargedstu
Member #: 908
gateshead
that sounds quite kinky!
I use the valvoline turbo.
My engine is currently self servicing...it empty's itself I just need to top up once in a while.
fab
Member #: 100
Parisien Turbo Expert
Paris\' suburb
motorbike oil, cause they have additives for gearbox.
which oil is that fab? Silklene pro 4?
fab
Member #: 100
Paris\' suburb
I prefer mobil one stuff, if not available I then buy motul 300v,
but then I think that about any good brand is ok, just be carrefull that it's NOT the late emission oil (catalysed ), to be sure they're all 0w or 5w something, 10w50, 15w50 the right ones.
Mr Joshua
Member #: 1954
Luton Bedfordshire
Addatives for gearbox, hmm. may give that avenue some serious thought. How long between changes?
Own the day
On 10th Jun, 2009 robert said:
shell rimula.
Didnt think star fish had shells
I use Millers CTV
Edited by Sprocket on 11th Jun, 2009.
T3Tone
Member #: 252
Sunny suffolk
millers ctv 20w50. expensive but imo the best oil for the a'series.
-MINI CLUBMAN 1380 TURBO-
fab
Member #: 100
Paris\' suburb
I change it every 5000 km, and the oil viscosity still "thick"and onctuose, not as the over oils I've used, that lok more like water when you drain them.
sx_turbo1
Member #: 4608
"Member"
valvoline VR1 racing 20w50,
we have loads of classic race teams ordering from us for it, and lots of customers who have performance classics.
me best mate has also been using it for over a year and works a treat.
