Home > Help Needed / General Tech Chat > What do you think?
ministef1
Member #: 1791
Cranleigh, surrey
Well i was in sutton the other day and in the town centre i noticed the red ignition light come on and the temperature start to rise, I drove about half a mile and then parked up and turned it of, turned out my bespoke alternator bracket had snapped. rubbish.....So when i got home i started it quickly just to check it was ok.....seemed fine......but also seemed to be down to 3 cylinders. (head gasket in my mind) guess i can't really tell till i do a compression test (sunday). Do you reckon it could be a plug or something breaking down under heat?
Just my luck again!
stef
"Cars are a lifetime of pain"
Ive had a similair prob where i went for a drive and lost all water, got extremely hot limped it into the garage and it wouldnt run properly after.
Turned out plugs has just fecked up.
Left a day, swapped plugs check compression and all was fine!
Mr Joshua
Member #: 1954
Luton Bedfordshire
Cheapest and easiest option first. Plugs!
Own the day
ministef1
Member #: 1791
Cranleigh, surrey
Thats the route i'm going to go, Don't think the plugs like the cooking effect!
cheapest and easiest option first = Compression check!
If you've got a compresion tester
ministef1
Member #: 1791
Cranleigh, surrey
managed to borrow one, I'll do it on sunday while i'm taking the plugs out......
Turbo Shed
Member #: 30
Epsom, Surrey
stef
well that explains all! have you checked that some theifing scum hasnt nicked bits off it as you drove along!
