Home > General Chat > SW5i
eaton_mini
Member #: 1649
West Sussex - dreaming of forced induction!
Will this camshaft fit a 998 A+ block???
I have a brand new billet one not being used and seems silly to leave it on the shelf, so thought I would try it with a blown 998 *happy*
Mr Joshua
Member #: 1954
Luton Bedfordshire
I will check the workshop manual
Own the day
The SW5i is for the MPi, you either need to supply an exchange MPi cam or pay for a billet one.
You just need the palin ordinary SW5 cam
However, that is what you want to do, or its the cam you already have, then yes it will fit a 998 depending on the oil pump, which you should be changing anyway, so it wont really matter
Edited by Sprocket on 10th Jun, 2009.
eaton_mini
Member #: 1649
I already have it in stock so to speak, and yes got a new oil pump that matches too :)
no wories then, as long as you are not going to use the mechanical fuel pump
