| Home > Help Needed / General Tech Chat > lower arm\ poly bushes | |||||||
![]() 384 Posts Member #: 4215 Senior Member |
11th Jun, 2009 at 08:53:26pm
hi everyone
11th Jun, 2009 at 09:52:22pm
Large G clamp? On 5th Sep, 2011 Vegard said:
11th Jun, 2009 at 09:58:27pm
12th Jun, 2009 at 01:07:24am
i dont have a big enough g clam, but that might just work. as for wlbow grease, i given it all i have..i it wont budge |
458 Posts Member #: 1840 Senior Member Kings Lynn, Norfolk |
12th Jun, 2009 at 09:17:47am
Make sure that the bottom arm pins haven't got the old metal sleves from the old bushes still on them.
12th Jun, 2009 at 10:04:27am
2nd that ^ On 17th Feb, 2009 Rob H said:
![]() 460 Posts Member #: 843 Senior Member Stoke-on-Trent. Duck. |
12th Jun, 2009 at 12:32:29pm
Can you pre-assemble everything (pin, bushes & arm) on a workbench ok? But struggle to get it together on the subframe?
12th Jun, 2009 at 12:36:27pm
What bushes are you using? |
12th Jun, 2009 at 12:56:47pm
hi, first of all thanks for the replies guys... |
12th Jun, 2009 at 01:09:51pm
12th Jun, 2009 at 06:36:58pm
On 12th Jun, 2009 t2clubby said:
![]() lolol got the problem sorted, the sleves were still on the dam pin.. you live and learn
thanks guys |
