| Home > Help Needed / General Tech Chat > OE Metro Turbo piston rings | |||||||
12th Jun, 2009 at 11:52:53am
I have a set of Hepolite 20831 pistons which I understand are OE for the Metro Turbo.
34 Posts Member #: 4608 "Member" |
12th Jun, 2009 at 11:58:54am
if you buy pistons fro ae they have the rings already fitted, maybe worth sending what you got back, and getting a set of ae pistons,
12th Jun, 2009 at 12:27:56pm
The Hepolite pistons have the AE symbol and an AE reference on them. They are not new, but came from an MT engine. |
12th Jun, 2009 at 12:33:23pm
What are the old oil cont rings like? If they are OK I'd be tempted to consider reusing them along with the new compression rings.
12th Jun, 2009 at 12:51:47pm
This is a common problem will all suppliers of ring packs, they seem to think the Metro Turbo pistons use the same ring pack as the non turbo, Not so, As you have found out, the oil ring is 4mm. They are the same ring pack as the Cooper S 19230 three ring pistons, as far as I am aware, the MG Midget also. They are difficault to find, so if you do end up haveing problems, you may have to buy Total seal rings Like I did. On 26th Oct, 2004 TurboDave16v said:
12th Jun, 2009 at 02:40:30pm
On 12th Jun, 2009 Tom Fenton said:
What are the old oil cont rings like? If they are OK I'd be tempted to consider reusing them along with the new compression rings. that should never be done. i'm not saying it definately wont work, but it is bad practice to do this, and isnt exactly ideal. |
12th Jun, 2009 at 02:42:58pm
On 12th Jun, 2009 tadge44 said:
The Hepolite pistons have the AE symbol and an AE reference on them. They are not new, but came from an MT engine. ah i see, sorry i was assuming they were new. i bought a set of brand new AE pistons (granted they were n/a 1293 pistons) but these came with piston rings already on the pistons. i cant personally give any more advice, as i dont know :) |
12th Jun, 2009 at 03:11:08pm
can i assume that the two thin scrapers are all one thickness, and that the extre0.5mm is amde up with the spring, therefore cannot you find some suitale springs ,machining the grooves is doable but if you get it wrong the jobs fucked,
12th Jun, 2009 at 03:24:04pm
I dont want to use the old oil rings as the problem was a bit of oil consumption and I am pretty sure its nothing to do with valve guides/valves as they are all new.
12th Jun, 2009 at 03:28:26pm
Oh, BTW, I searched first and tried to see if I could get Totalseal rings, but they dont seem to list them ATM for A series 1275 |
12th Jun, 2009 at 06:26:42pm
http://www.totalseal.com/SearchByApplication.aspx
12th Jun, 2009 at 07:18:52pm
can't find 3.5mm/1/8 oil cont ring from the link. have you a part number that's very interesting, since I had to machine the groove, and already have lost two set of pistons. |
12th Jun, 2009 at 07:53:51pm
On 12th Jun, 2009 fab said:
I had to machine the groove, and already have lost two set of pistons Well, try remembering where you put them? Maybe taping one of those 'whistle key finders' to each piston next time you machine one? On 17th Nov, 2014 Tom Fenton said:
12th Jun, 2009 at 08:04:48pm
can't find 3.5mm/1/8 oil cont ring from the link. You wont, they do not exist for the A series, and if they do they are odd ball. You could contact Performance Unlimited in Pontefract who are a Total Seall UK dealer. They may be able to sort out a custom set of rings if you give them the dimentions. They will be sent from the US. On 26th Oct, 2004 TurboDave16v said:
12th Jun, 2009 at 10:50:45pm
Given the above comment by Fab, it appears that I am not the only one to have 3.5mm oil rings.It certainly appears to be a rare specification.
280 Posts Member #: 4340 Senior Member sideways, Birmingham |
13th Jun, 2009 at 01:51:57am
i know this game, the wound sping things the bit that cocks it all up, im poor and resoursefull and used a half moon diamond file on the ringland to give clearance for the spring, you dont need to take much out ( 1-1.5mm) and if you look at new 8.4cr pistons at minispares thayve lost a lot of metal hear anyway, hope this helps
On 15th Dec, 2009 fastcarl said:
sell the lot to me for £70 pounds and i'll let you stand on the outside edge and look on my inner circle of closest frinds, lol carl FOR EVERY WELL THOUGHT OUT AND WELL EXECUTED PRICISION JOB EVER CONCIEVED, YOU CAN GUARANTEE THAT SOMEWHERE IN WALSALL OR THE BLACK COUNTRY THERE WILL BE A BLOKE TRYING TO ACHIVE THE SAME BY MEANS OF "ITIN IT WI LUMP AMAR" |
13th Jun, 2009 at 07:56:24am
I had to machine the groove, and already have lost two set of pistons Well, try remembering where you put them? Maybe taping one of those 'whistle key finders' to each piston next time you machine one? Edited by fab on 13th Jun, 2009. |
the barb grill!
