Page: |
Home > General Chat > Just had my car on the rollers and finally a figure im not embaraced of! | |||||||
2924 Posts Member #: 95 Post Whore liverpool-on-sea |
15th Jun, 2009 at 07:05:08pm
well done excellent result that!! no longer a series, but still 1.3 turbo.
2909 Posts Member #: 83 Post Whore Glasgow, Scotland |
15th Jun, 2009 at 07:21:57pm
On 15th Jun, 2009 Rob Gavin said:
how was crail? annoying lol 28 runs all consistant mid 13's i have never been able to get past a 13.4 at crail regardless of stripping the car or trying sticky tyres, launch in 1st, 2nd, lots of air in the tyres, no air in the tyres, roll out gently riding the clutch, roast the tyres, everything .. bloody car really should get some weight out her. :) interestingly even having a passenger in the car doesnt affect my times Cheers T3tone and carl! Brmatt, the reason is pretty simple :) and 4 reasons. 1. 1.6/8 liners are wafer thin, like after-eight mint thin. 2. there are two types of 1400 block, eary "wet" liner, and later "damp" liner. the 1600 and 1800 are only avaliable in damp liner. Simply the damp liner is supported half way up the liner, there is absolutely NO support for the top of the liner atall, so that after-eight mint thick bit of steel can wobble and crack all over the place. on wet liner engines the top of the liner is held by the block and the rest of the liner dangles down(surrounded by coolant) so the buisness end of the liner, where the power is made, is supported. a late damp liner bottom end, would you trust them to boost 3. on the wet liner 1400's the liner has a ridge which extends up inside the fire - ring of the gasket, protecting it from the flame front. less stress on teh gasket! 4. Head gaskets never failed on the early engiens. it was the redesign of the engien to damp liner to increase the capacity that brought about alot of the head gasket pain :) a wet liner bottom end for comparrison, note the liners are nearly twice as thick AND supported by the alloy block all the way around :) Edited by evolotion on 15th Jun, 2009. turbo 16v k-series 11.9@118.9 :)
6744 Posts Member #: 828 Post Whore uranus |
15th Jun, 2009 at 07:23:26pm
well done denis , you should be bloody proud ! Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
15th Jun, 2009 at 07:34:08pm
On 15th Jun, 2009 robert said:
well done denis , you should be bloody proud ! cheers :) my expereiments with finding a cheap WI pump have failed though, all i have tried so far have siezed after a weeks use may have to call aquamist and open my wallet yet :( not been brave enough to try it on the car yet though, still on the test rig! if anyone on here knows of a reliable and cheap water pump capable of sustaining 60+psi let me know pelase 8-) turbo 16v k-series 11.9@118.9 :)
15th Jun, 2009 at 08:19:32pm
well done denis , you should be bloody proud ! cheers :) my expereiments with finding a cheap WI pump have failed though, all i have tried so far have siezed after a weeks use may have to call aquamist and open my wallet yet :( not been brave enough to try it on the car yet though, still on the test rig! if anyone on here knows of a reliable and cheap water pump capable of sustaining 60+psi let me know pelase 8-) Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
15th Jun, 2009 at 08:49:45pm
lol i just used a windscreen washer pump . cowboy turbo 16v k-series 11.9@118.9 :)
510 Posts Member #: 1592 Smart Guy! mainland europe near ze germans |
15th Jun, 2009 at 09:21:55pm
have you read this rbracing bit? ( http://www.rbracing-rsr.com/waterinjection.html) of course they build THE BEST..
Edited by Sir Yun on 15th Jun, 2009. That sir, is not rust, it is the progressive mass reduction system
15th Jun, 2009 at 09:26:32pm
LOL,
15th Jun, 2009 at 09:43:46pm
im keen to only inject after the turbo, so rules out low pressure pumps and pre-turbo stuff. alot of the american ktis ude "shureflo" pumps, just got to find a cheap stockist and also come up with a novel flow meter to limit boost should the pump fail :) turbo 16v k-series 11.9@118.9 :)
127 Posts Member #: 1871 Advanced Member Chesterfield, Derbyshire |
15th Jun, 2009 at 10:41:52pm
I never understood why people went for the 1400 VVC cause my 1800 VVC Rover is running 143bhp standard,
16th Jun, 2009 at 07:01:05am
just have a pressure switch in the pre solenoid water line denis , cuts boost if theres no water pressure .eg cuts power to the boost controller . on a riley i worked on with a gypsy moth aero engine , it ended up with a lemonade bottle full of water ,then pumped up to a rediculous pressure ,then just a valve for on and off ,that worked well . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
Site Admin 9401 Posts Member #: 58 455bhp per ton 12 sec 1/4 mile road legal mini Sunny Bridgend, South Wales |
16th Jun, 2009 at 10:18:19am
very impressed with this, well done. do you know what weight the K series engine is? Team www.sheepspeed.com Racing
Site Admin 15300 Posts Member #: 337 Fearless Tom Fenton, Avon Park 2007 & 2008 class D winner & TM legend. |
16th Jun, 2009 at 10:24:02am
Bloody hell, those liners really are thin, my 205 is now running over 1 bar on wet liners, they have no support at the top either, but are quite a lot more substantial than those!
16th Jun, 2009 at 07:04:07pm
sweet robert :) . will come up with something before avon anyways, feel class I may be a bit tougher this year, certainly quite a bit stirring on the 16v forums :)
326 Posts Member #: 1323 Senior Member |
17th Jun, 2009 at 12:33:28am
Seems like the wrong way around ?
17th Jun, 2009 at 12:50:10am
On 17th Jun, 2009 carl talbot said:
Seems like the wrong way around ? aren't wet liners the ones surrounded by coolant damp liners supported by block , but getting damp with coolant my renault 16tx has wet liners , they fit into block at base , large squared off tops that support each other no my descriptions are the correct way around for the k :)this engine is different from the norm. on the damp liner engines 2/3 of the liner is held by the block at the bottom and never gets wet, the top 1/3rd is in direct contact with the coolant and gets wet. the wet liner engines have the very top of the liner supported by the block, and the very bottom of the liner is sealed by an o-ring the entire liner inbetween is exposed directly to coolant :) i guess the damp liner k is a wet liner in the traditional sence but the names have stuck this way to differenciate between the two block types :) turbo 16v k-series 11.9@118.9 :)
20th Jun, 2009 at 10:50:59pm
look at this for a pump :
Page: |
