Home > Help Needed / General Tech Chat > erratic power delivery.
MarkGTT
Member #: 1194
Shropshire.
Hi, im after some help..
As some of you will know my car is now road legal, great, however actually driving it is a right pain.
Firstly it starts and ticks over fine – and all in all first gear isn’t too bad, however the power delivery can be a bit erratic and this is where the problem begins.
When I shift up to second (and any subsequent gear) it is very unpredictable, sometimes when accelerating I will get nothing at all, no increase in revs and no go resulting in the car stalling and me having to crank it again.
If I do get revs when I accelerate then the power delivery is very erratic and im hopping down the road.
This is my first few runs in a turbo mini, any ideas what I should be checking first?
Could it be the timing (megajolt) or should I be looking for the problem somewhere else??
Cheers, Mark.
pinkyandnobrain
Member #: 2588
Pretoria South Africa
Mark is the same in all driving situations ? ie driving slowly, cruising or nailing it ?
Does it miss-fire or just cut out and then run on all cylinders again ?
"Try to take over the world!"
MarkGTT
Member #: 1194
Shropshire.
a little worse when giving it the beans.. but its also like it doesn’t want to cruse, so i suppose it all driving situations.
no misfire and its running on all 4.
has it been set-up?
do you have a wideband on it? Whats the mixture like?
MarkGTT
Member #: 1194
Shropshire.
not set up yet.. first run really. Thought i should be able to get it somewhere close before the rolling road.
no wideband but i have the option to fit a mates if i weld a boss in..
to be honest the more i think about it the more it feels like fuelling / a/f ratio..
Turbo Shed
Member #: 30
Epsom, Surrey
the running out of puff can sometimes be a blocked or restrictive fuel filter, i had it before, ran fine on the driveway, took it down the road and the carb ran out of fuel, crank it and it would run for a bit and do the same.
same goes if you mod a standard tank and leave the strainer in the bottom
MarkGTT
Member #: 1194
Shropshire.
this makes sense, fuel filter is fine but i haven’t removed anything from the tank..
just found out that it will also stall if sat idling for a while too.
how and what do i remove from the tank? sounds like this is worth a try!
cheers
richminiturbo.
Member #: 719
Horndean - Near Portsmouth
Wouldnt be related to dashpot oil would it?
Its suprising how many issues it causes.
MarkGTT
Member #: 1194
Shropshire.
checked that today, its at the level it should be.. *oh well*
banking on this tank issue now.
Nick
Member #: 154
Midlands
give us a shout if you get stuck tomorrow dude, don't think i've got much planned apart from washing the car if its not raining.
MarkGTT
Member #: 1194
Shropshire.
cheers - will drop you a text. :)
fab
Member #: 100
Parisien Turbo Expert
Paris\' suburb
does it do the same from cold and heated, you could have issue with float bowl heated by the turbo. it does a bit like this.
mixture too lean or rich ?
search for the T peice trick which turbo dave wrote
i had this, loose earth strap!
strange but true!
had another issue on a different car, goosed pump!
Turbo Shed
Member #: 30
Epsom, Surrey
if you run a non mpi or spi tank and also a fuel return to the tank then you HAVE to remove the strainer on the pick up pipe inside the tank.
to remove it tape a broken hacksaw blade to a stick and stab the strainer through the filler neck ( spearing the mesh is as good as removing the hole thing)
MarkGTT
Member #: 1194
Shropshire.
problem fixed!
Me and nick removed the strainer on the pick up pipe inside the tank and then noticed a bit of a school boy error..
it pains me to say it but i had wired the fuel pump up wrong.
Its on a relay connected to oil pressure, however i had the pump going 'off' when we had oil pressure not 'on'. :$
so i would only ever have the fuel that was in the lines.. then it would stall and the pump would come back on etc.
anyway the car is now running ok, still some tuning required as suspected but apart from that its all good.
thanks for all your help.
Edited by MarkGTT on 14th Jun, 2009.
Nick
Member #: 154
Midlands
don't forget to stick the fuel filter back in dude!
MarkGTT
Member #: 1194
Shropshire.
as if..
(runs off to put filter back in!)
