Home > General Chat > SC Comps steel rods
eaton_mini
Member #: 1649
West Sussex - dreaming of forced induction!
Is anyone running a set of these on here??
I got one of the steel cranks last year when they came up at a 'special' price and was wondering if it was worth stumping up for the mating rods or just sending mine to MED for working?!?!?
These are std A+ 1275 rods by the way nothing special
If you decide to modify standard rods you could try carl @ force racing for rod modification. fastcarl on the forum.
http://www.force-racing.co.uk/engine/
Its where I will be going when I get my rods modded.
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
Don't steel cranks have S journals?
On 30th Apr, 2010 Rod S said:
Gary's description is best
John got some made with A+ size big ends. I'm lucky enough to have one under the bench for a rainy day.
The way I look at it is that these steel rods may not be needed in a lot of cases, but looking at the cost of getting a standard set modified there doesn't seem to be a massive amount of money in it.
Plus they seem to be about 100g lighter then even a lightened set.
These are my thoughts on it, they may not be correct though!
I use them, they heavier than other steel rods out there, but not as expensive.
The only fault I had with them was that they fouled the bottom of a standard bore, But I don't think this is limited to just these rods, Im sure I read it some where, Second edition TBASE? but I cannot for the life of me find it
My Carillo rods also required the bottom of the bore to be relieved to provide clearance.
eaton_mini
Member #: 1649
So they should be ok on a 1380 then??
I agree that once I have my rods sent off worked and get them back theres about 50 quid in it.............
eaton,
I have one of those cranks too,
I'll PM you some tips tonight
eaton_mini
Member #: 1649
mini13, just the man i wanted to talk too as well about your 7 port head!
Will converse later then my man!
I'm sure the SC rods are good bits of kit, we have a set on the shelf, but they are heavier than a worked set of A+ rods.
eaton_mini
Member #: 1649
Alot heavier???
I was thinking more of strength than anything else, I know Ill never rev it past 7-7.5K as I dont have the balls, but would be nice to know it would survive it I did LOL
And before its said, Im going for a steel flywheel too, just dont know which one yet. How badly does the ultra light make them idle?? Bearing in mind Ill be using it with a 7 port with something like a piper 300 cam..........
What do you weigh them in at? my estimate was going by the weight quoted on the sc website vs the wight of a worked rod being about 595g
I picked one of the h section rods up the other day, and there didn't seem to be a lot of weight to it. But then again I'm not a pair of scales.
I'll get the figures for you guys
On 15th Jun, 2009 eaton_mini said:
Alot heavier???
Im going to buy one of those new MED Verto flywheels next year, as the preverto is a royal PITA, Verto seems to be fit and forget, and the RTS version looks to give the clamping forces most turbo engines need.
eaton_mini
Member #: 1649
Thats weird, cos every engine I have had that is Verto has been a pain in the chuff to remove! Every Pre-verto Ive managed to get the flywheel off again............oh what to do!
My verto held up fine a 15psi even though it was coated in oil. :)
Im just in the process of removing the verto, hopefully it'll come off okay.
GaryOS
Member #: 2810
Dublin, Ireland
Ah, thanks for clearing that up Phil. I thoughtI was being a bit thick
erm...
erm...
