| Home > Help Needed / General Tech Chat > You Loss any power by keeping the ECU | |||||||
621 Posts Member #: 393 Post Whore Oulton Park |
12th Nov, 2004 at 09:42:29pm
13th Nov, 2004 at 12:01:23am
do a seach on here what the ecu does, basically bin it and fit a bleed valve of some description do another search.
Edited by Carl on 13th Nov, 2004. no longer a series, but still 1.3 turbo.
13th Nov, 2004 at 11:28:49am
you won't lose peak power, but you will lose midrange torque - and around 50% of the fun factor... On 17th Nov, 2014 Tom Fenton said:
13th Nov, 2004 at 09:03:38pm
I was thinking about keeping the ecu (injection) you cause i wouldn't have to do any wire plug her in and a way i go! I just wondered by doing the wireing though the dizy to you gain anymore power?
14th Nov, 2004 at 11:31:04am
YOU LADS GIVEN UP ANSWERING |
14th Nov, 2004 at 11:44:59am
i wouldn't have thought you could use the standard mini ECU at all dude. there's no sensors on the turbo lump to give it any info.
14th Nov, 2004 at 08:12:07pm
std engine isnt injection ....
AlexF |
14th Nov, 2004 at 09:09:07pm
zeemax's old engine was injection i think, alex no longer a series, but still 1.3 turbo.
14th Nov, 2004 at 10:38:45pm
Very true minime so whats the best intercooler?
14th Nov, 2004 at 11:44:39pm
Zeemx...
15th Nov, 2004 at 11:17:20am
Thanks for the advice the only reason i mentoned the ecu is that the guy from avonbar said you can do it through the ecu you but i think i've got what your saying so i'll have a go at your way SORRY THE ONLY WAY LOL what you thinking about big intercoolers then a no go what you running on yours?????? |
15th Nov, 2004 at 11:21:39am
Maybe he was getting confused and thought you were on about the metty turbo ecu. All this does is regulate boost. bit of a waste of space and wiring.
15th Nov, 2004 at 11:24:04am
thanx i thought that was a bit weird |
15th Nov, 2004 at 11:24:46am
Thoughts on intercoolers ????? |
15th Nov, 2004 at 11:36:32am
check out some posts via the search. this has been covered a LOT of times |
15th Nov, 2004 at 12:44:04pm
Having seen Tim's and Vegard's mates instalations, I'd be looking at the 2wd cosworth intercooler mounted in front of the spark plugs. These are fantastically efficient units - and makes fora VERY neat install.
