| Home > Help Needed / General Tech Chat > Flywheel keyway | |||||||
![]() 184 Posts Member #: 346 Advanced Member Portsmouth |
16th Jun, 2009 at 09:40:42am
Hi, im having difficulty installing the keyway to the end of the crank. The keyway does not fully insert. Picture below:
1310cc TWINK - T Conversion |
16th Jun, 2009 at 01:18:40pm
The key should sit all the way home with the minimul amount of assistance required. Its hard to see whats going on from that photo.
Own the day
16th Jun, 2009 at 04:19:44pm
Im struggling to get a good picture, but see pic below:
Edited by Mr Mini on 16th Jun, 2009. 1310cc TWINK - T Conversion |
16th Jun, 2009 at 05:50:23pm
looks correct to me. You don't want the keyway to bottom out on the crank, as that would make it impossible to push the flywheel any further in on it when torqueing it up |
16th Jun, 2009 at 06:57:38pm
So long as the flywheel is sitting firm on the taper end of the crank (without the key washer) and the flywheel washer face is protruding beyond the crank end face, all should be well.
16th Jun, 2009 at 07:01:50pm
pfft,
16th Jun, 2009 at 07:52:06pm
ahh.. I understand.
16th Jun, 2009 at 08:06:07pm
Simplest way is to do the big bolt up fully - to seat the flywheel properly - then take it out again and look at the gaps in the key washer.
16th Jun, 2009 at 08:14:00pm
Thanks for your help.
