| Home > General Chat > Anyone ever used powerrmax 73.5mm pistons in a forced induction engine? | |||||||
![]() 667 Posts Member #: 5232 Post Whore basingstoke |
16th Jun, 2009 at 11:07:26pm
evenings chaps!
Mr. Prawn, the friendly Crustacean- slowly making steps towards forced induction. |
17th Jun, 2009 at 08:47:46am
yep got powermax's in the 7 port, dished out to 17cc.
17th Jun, 2009 at 10:09:55am
sweet, that's what I wanted to hear! i just really fancy getting a few miles on the charger setup to see what it's like before spending big money on a new bottom end. the current setup will happily take the power, I was just unsure on how the pistons would cope. Mr. Prawn, the friendly Crustacean- slowly making steps towards forced induction. |
17th Jun, 2009 at 10:11:23am
well mine have seen short 15-20 psi squirts so you shopuld be fine with an sc setup especially if its just for triallying On 28th Aug, 2011 Kean said:
17th Jun, 2009 at 10:12:02am
oh also on my trial lump i just used 2 headgaskets to knock the cr down. On 28th Aug, 2011 Kean said:
17th Jun, 2009 at 12:25:27pm
2 head gaskets? that sounds scary! Did it actually survive any boost like that?
17th Jun, 2009 at 01:24:08pm
yep, 2000 miles on 3psi boost. llokedf fine when i took them off On 28th Aug, 2011 Kean said:
17th Jun, 2009 at 06:11:01pm
yes i think a few on here use them pistons with great results :) Best 1/4 mile 13.2 seconds @116 mph
17th Jun, 2009 at 06:29:40pm
two head gaskets isnt the way to go its a bodge at best!
17th Jun, 2009 at 07:37:52pm
I know what you mean benross. my plan is to build a proper low compression engine with 18cc pistons and a decent head. I'm planning on using the cometic MLS gasket just as a temp to get the CR down on my current engine so I can test the charger setup on an 'unimportant' engine so to speak. then, when i know it works, I'll rebuild with 18cc acralites and a head with chambers to the correct volume for my required CR. Mr. Prawn, the friendly Crustacean- slowly making steps towards forced induction. |
