Home > For Sale > MG Metro Turbo
Gilly2006
Member #: 1720
Bamber bridge, Preston
MG Metro Turbo for sale.
the car has genuine miles but the engine has only a couple of thousand miles use.
the car has been used as a daily runner until recently.
the metro has tax and mot until november 09.
had to sell it as the wife was struggling to drive it, and also now got a car that is slightly better on fuel.
There is a list of mods is as long as my arm.
no tire kickers please, open to offers but no stupid ones please.
The mods are as follows:
Engine:
A series 1293cc
+20 10cc omega pistons
stock rods
Avonbar high capacity oil pump
uprated Water pump
Double core radiator
Crank lightend and balanced
Piper phase 2 Camshaft with followers and double springs
Ported and polished cylinder head
chambers machined to 30cc to lower compression to 8.5.1
Standard valves including sodium exhaust valves
one off handmade Side mounted exhaust manifold.
T3 Hybrid Turbo with 38mm External wastegate
Braided oil feed
2" maniflow exhaust system
engine steady
8mm copper fuel lines front to back
Bosch fuel pump
Adjustable Fuel regulator with gauge
Battery Relocated into boot
8mm manicore leads
Megaspark 3 race coil
micro dynamics Turbo retard ignition unit
10 PSI carb needle
Green dashpot race spring
Plenum chamber modified for dump valve and intercooler.
Cosworth front mounted intercooler
Trasmission:
Ultra light steel flywheel
AP bonded race plate
Grey pressure plate cover
Centeral oil pickup
3.105 final drive[for slight more top end speed]
race xpin differential
Chassis:
Braided Brake hoses all round
Grooved and drilled front discs
Greenstuff brake pads
Dot 5.1 brake fluid
Adjustable hand made front shock absorbers
pollybushed front antiroll bar and bottom arms
suspension struts machined down to race spec
standard Metro turbo alloy wheels with Pirelli tires.
Interior:
Mint condition
Tims Boost Gauge
Tims oil pressure Gauge
Tims Vacuum Pressure Gauge
Kad Quickshfit
CD player with ipod connection
Boost pressure is at 12PSi
car is not for the faint hearted
will not find another metro turbo like this and will also not be dissapointed.I've spent alot of money and time into this metro so who ever buys it will save thousands.
Body is in good condition, the car has never been welded and is mint underneath
There is one dint in the boot which some skumbag kicked in while the car was parked, but its nothing serious.
07920816452
Item Condition: Good apart from the slight dint in the boot.
Price and price conditions: 2300ono
Extra Info:
Pictures:
Contact Details: 07920816452
Delivery & Conditions of Delivery: collection
I have pimped this on the metro owners club for you.
