Home > Technical Chat > JANSPEED turbo clutch slipping
JC T ONE
Member #: 2974
Hi all, I have now covered 340 miles, and have changed the jet in the wastegate, but now the clutch is starting to slip when the boost kicks in*oh well* I have a CP2084-41 rally/race AP racing plate in,
and left the flywheel, as it is the one JANSPEED put in, ¨so it must be the clutch cover thats not up to the job*frown* what can you turbo guys recommend??? orange or grey?? as I really dont want to put one of these sintered plates in---I want the car to be drivable, and those sintered plates are not nice in town traffic, I have also seen a diaphram/cover called dubbel grey, at Avonbar, is that ewen better for turbo?? or what?? hope to get some good advice from you turbo driverz8-)
Edited by JC T ONE on 26th Jun, 2009.
I'd fit a grey cover. The single grey will be fine for most, the double grey's only needed if you're pushing really big torque figures.
as phil says but ........... also have 1.5mm machined off the 3 lugs on the back plate to give extra! clamping load as per turbo daves modd advice
you should be fine then
JC T ONE
Member #: 2974
well now I have ordered a new AP racing center plate, and a grey pressure plate, hope this is up to the job then ?? you have to remember my car is very heavy with all the WP stuff inside??
is there a chance that you (Phil) could take your cover off and check the plate on your JS ?? as it most likely is the original still sitting there8-) and do yourself a favor --- get that nice engine in a car:) you cannot belive how nice and quiet this setup is *smiley* read the Vizard bible again, all he writes about this setup is 100% spot on8-)
JC T ONE
Member #: 2974
now thats a fine sounding yellow beast in those vids8-) I will see if I can get someone with a camera with me one day? but dont expect to hear much--its really nice and quiet inside, if I roll down RH side window, and drive with something on my RH side, that will throw back the sound -- thats a WHOLE different thing, as you then can hear the turbo whine when pressure builts up, and it goes to work:)
Edited by JC T ONE on 27th Jun, 2009.
Jay#2
Member #: 648
Northern Ireland (ex AUS)
I take it the JS setup has a pre-verto setup then? Didn't know that.
On 7th Nov, 2008 Nic said:
naeJ
m
Yep ! :)
JC T ONE
Member #: 2974
Hi guys, thought I would update this old hread.
I had visitors over from UK last summer, so I finally pulled myself together, and got it out of the hybernation its been in since 2009, in order to fix all the small issues.
Thanks for your advice, I did as you suggested = Grey cover, and had the back plate lugs machined.
But I also found out why it was slipping = the fly wheel were shaped like a bowl,
so I had the surface machined, on both parts.
I could now take my guests from England out for a drive, without any clutch slip *happy*
Jens Christian
