| Home > General Chat > arse. | |||||||
830 Posts Member #: 908 Post Whore gateshead |
27th Jun, 2009 at 12:43:03am
picked up my shiney new canems ecu kit today, spent all night wiring it up and checking bits over. tried to start it and it wont run.
balls to the blower!!!
27th Jun, 2009 at 01:44:44am
arse indeed (
27th Jun, 2009 at 10:53:33am
yes, but the jets are large enough and should make it fire. balls to the blower!!!
27th Jun, 2009 at 11:04:55am
float issues?
27th Jun, 2009 at 02:49:06pm
start on the chokes??? What size jets are they? Webber ones fit on the mains if you are stuck.. and the screw is 2.5 turns out as its a fuel screw not an air screw if they are the same as mine...
27th Jun, 2009 at 07:42:28pm
nah. the choke didnt make any differene. it would run if you squirted fuel down the carbs. then if you rev it hard it would choke itself. cant tell if its a mapping issue or a carb issue. i tied drilling out a pair of jets a little bigger than the modded bogg ones, but it made no difference. the mixture screw was all the way out balls to the blower!!!
27th Jun, 2009 at 08:00:46pm
What were you running it on before? Has it worked with these bike carbs before you changed the ECU?
27th Jun, 2009 at 08:44:54pm
what about the slow jets? did they drill them too? Is it over fuelling or under? I run a supercharger and I don't care the TB is on the wrong side.
667 Posts Member #: 1376 Post Whore clock tower with a sniper rifle |
27th Jun, 2009 at 09:06:10pm
vacum carbs?
internationally known as "big" swede |
27th Jun, 2009 at 10:02:00pm
megajolt and a hif44 but it was poo so i ditched it. slow jets?? i presume they did drill them too. i cant tell if its over or under fuelling. i think its under fuelling. the carbs are zx9 ninja carbs so i dont know if they are vacuum carbs. balls to the blower!!!
27th Jun, 2009 at 10:11:07pm
stu,
28th Jun, 2009 at 12:30:09am
if you take the float chamber bottom off there are are three jets,
28th Jun, 2009 at 10:27:47am
ah. ok. i will try that. i tried drilling out the main jet bigger still on a spare pair of main jets i had and it didnt make a differenct, so that might be why! when it did run for a short time, i revved it and watched the boost gauge. it went to 25psi!!!! balls to the blower!!!
28th Jun, 2009 at 10:49:44am
main jet is 3/4-full throttle, try raising the needles a couple of clicks for more fuel in the middle, internationally known as "big" swede |
