| Home > Technical Chat > A SERIES ENGINE AND AN A+BOX?? | |||||||
297 Posts Member #: 2276 Senior Member sheffield / derby |
27th Jun, 2009 at 10:45:19am
hi all
27th Jun, 2009 at 11:04:32am
You will need the A+ transfer housing to go with the gearbox because the middle of the drop gears has a larger shaft (hence larger bearing hole in the gearbox casing) which, in turn, means you need the full set of A+ drop gears.
27th Jun, 2009 at 02:58:35pm
27th Jun, 2009 at 02:59:44pm
Cheers Rod, Thats what i wanted to hear |
27th Jun, 2009 at 04:03:05pm
OK,
27th Jun, 2009 at 05:12:25pm
cheers again guys
