| Home > Help Needed / General Tech Chat > Bulkhead box | |||||||
![]() 115 Posts Member #: 2240 Advanced Member Co.Cavan....Ireland |
27th Jun, 2009 at 11:42:03pm
When fitting a bulkhead box,why do you cut the bulkhead at a angle on the right hand side? Bending the rules and ruling the bends,Since 1959 |
28th Jun, 2009 at 12:00:23am
To give clearance around the actuator & air intake pipe. |
![]() 362 Posts Member #: 114 Senior Member Porto/Portugal |
28th Jun, 2009 at 12:00:57am
Pedro Silva
28th Jun, 2009 at 11:15:53am
Thanks lads. Bending the rules and ruling the bends,Since 1959 |
28th Jun, 2009 at 12:52:26pm
above is a good pic!
![]() 1105 Posts Member #: 1504 Post Whore Westbury, Wiltshire |
28th Jun, 2009 at 03:58:58pm
Or you could just weld on a 3 inch extension to the standard Avonbar bulkhead box as I did so that it didn't matter what dia actuator you could use.
28th Jun, 2009 at 04:17:38pm
That's very tidy ! :) |
28th Jun, 2009 at 04:17:48pm
Very nice Richard.....
28th Jun, 2009 at 10:35:33pm
28th Jun, 2009 at 11:07:00pm
Welded in the box this mornin,Looks like it was always there. Bending the rules and ruling the bends,Since 1959 |
1st Jul, 2009 at 01:27:17am
Rod / Vegard.
1st Jul, 2009 at 06:33:16pm
Always helps to modify the bottom of the box so it slopes, otherwise its a damn water trap. On 19th Jan, 2010 wil_h said:
1st Jul, 2009 at 06:39:34pm
On 1st Jul, 2009 Jason G said:
Always helps to modify the bottom of the box so it slopes, otherwise its a damn water trap. ![]() Nice touch noted
Own the day
1st Jul, 2009 at 07:00:59pm
Always helps to modify the bottom of the box so it slopes, otherwise its a damn water trap. ![]() Nice touch noted ![]() On 19th Jan, 2010 wil_h said:
1st Jul, 2009 at 08:24:18pm
Thats actually a very good igea with the slope Bending the rules and ruling the bends,Since 1959 |
1st Jul, 2009 at 09:24:29pm
1st Jul, 2009 at 09:29:11pm
I think you could be on to something there Bending the rules and ruling the bends,Since 1959 |
1st Jul, 2009 at 09:47:13pm
147 Posts Member #: 814 Advanced Member Utrecht, The Netherlands |
1st Jul, 2009 at 09:53:17pm
Be aware that cutting the bulkhead on the right hand side (viewed from the front of the car) is not an option on left hand drive cars. You need that part of the bulkhead for the clutch master cylinder and the brake pedal assembly (when using a late type remote servo) or the brake master cylinder itself.
1st Jul, 2009 at 09:55:06pm
Any other tips for me Bending the rules and ruling the bends,Since 1959 |
.I guess thats another job to do at the weekend
