Home > General Chat > Early Metro Turbo engine question
Mr Joshua
Member #: 1954
Luton Bedfordshire
Am I correct in thinking that the only difference between the Mk1 and Mk2 metro turbo engine set-ups is the case hardened crank in the Mk1 not in the Mk2 and the fuel pump resistor fitted to the Mk1 & not to the mark 2?
I pressume the the rest of the parts are the same across early and later models in respect to piston's, cam shaft, inlet and exhaust valves & gearbox?
Own the day
I know my mk1 engine had a seprate ignition module for the dizzy mounted on the electric fan housing as opposed to the integrated noe on the later dizzys.
Internally, I've no idea
Jason G
Member #: 1459
En-suite user
Braintree, Essex
I think it was pre 85 or 86 that had the different crank. From various other comments, it doesn't make any difference. Never had one personally.
On 19th Jan, 2010 wil_h said:
When did they change to the non-grooved bottom main bearing shells ???
The Metro A+ I've built has the grooved bottom shell but it may well be before the turbo derivative came out.
Mr Joshua
Member #: 1954
Luton Bedfordshire
Both my engines have the non groved bearings in them cant decided whats better with or without.
This engine has the inertia type starter which leeds me to think its the ealy type and hydraulic clutch.
Own the day
metroturbo
Member #: 989
North Yorkshire
Fuel pump resistor is fitted to all metro turbos.
Mr Joshua
Member #: 1954
Luton Bedfordshire
Really, never found it on any of my Mk 2's where was it fitted?
Edited by Mr Joshua on 2nd Jul, 2009.
Own the day
metroturbo
Member #: 989
North Yorkshire
Under the battery tray.
