Home > Help Needed / General Tech Chat > diff housings
stefaz
Member #: 1656
stoke-on-trent
Are they paired to the gearbox or can you just transfer them over?
Mine has snapped on the daily drive today so ideally I'd just like to swap it with a spare I have rather than swapping a box.
Cheers gents
Ant
1972-ANGUS
Member #: 3894
sallys gap. garden of Ireland
you can swap them from amother box if you wish.
you still have to shim up up correctly
they are matched to the gearbox, but people have got away with swaping them.
for a std lump I would be tempted to try one on and see is there is a ridge in the bearing holes, you might just get lucky.
stefaz
Member #: 1656
stoke-on-trent
Wonderful gents, will give it a go as soon as I get chance
Find a different casing or be prepared for spun diff bearings/leakages.
