| Home > General Chat > well can you ??? | |||||||
11 Posts Member #: 6531 Member |
1st Jul, 2009 at 12:09:05am
can u put a turbo on a weber and is it hard
Edited by minimadmick on 1st Jul, 2009. |
1st Jul, 2009 at 12:11:29am
Most Webers are made from aluminium alloy and are quite hard. Not as hard as steel though.
1st Jul, 2009 at 12:17:12am
Haha but seriously
1st Jul, 2009 at 12:22:45am
You could try this:
1st Jul, 2009 at 11:27:26am
use the search and you will find some companies have done it but iirc delrotto's can be turbo'd Jan speed metro turbo is one Drives
1st Jul, 2009 at 01:14:46pm
Webbers are not sealed so if you were to have a set up like the standard set up you would end up blowing air out of all the shaft seals.
Own the day
55 Posts Member #: 6376 Advanced Member oxon |
1st Jul, 2009 at 09:55:54pm
if you put the whole carb into a plenum you may need to foam fill the float in the float bowl.
1st Jul, 2009 at 10:46:12pm
Firstly, why would you want to? Whats wrong with a nice SU? On 7th Nov, 2008 Nic said:
261 Posts Member #: 713 Senior Member Western Australia |
2nd Jul, 2009 at 12:58:04am
Put a Weber on a turbo, it's easier (draw through). On 24th Dec, 2008 Nic said:
eyh? im drubj but very confused##]#IU |
