| Home > Help Needed / General Tech Chat > Thanks to Robert for advice regarding fuel starvation on the van. | |||||||
![]() 1105 Posts Member #: 1504 Post Whore Westbury, Wiltshire |
1st Jul, 2009 at 02:22:33am
Just a short TY and a bit of a dit on Lessons Learned. Certainly for me anyway.
1st Jul, 2009 at 08:03:25am
Point 3 second paragraph is wrong. The DV should have its signal from the manifold, after the throttle disk, otherwis it'll do bugger all.
1st Jul, 2009 at 08:16:58am
On 1st Jul, 2009 wil_h said:
Point 3 second paragraph is wrong. The DV should have its signal from the manifold, after the throttle disk, otherwis it'll do bugger all. The actuator should have it's signal from the plenum, which is not mentioned above. The actuator is mentioned in point 2, but I don't think it makes much difference where you take it from so long as it is before the butterfly. Although it makes sence to put in the plenum from a control point of view. I did some drawings on this a while ago, a picture speaks.... you know the rest. http://www.turbominis.co.uk/forums/index.php?p=vt&tid=257121 http://www.twin-turbo.co.uk
1st Jul, 2009 at 09:28:28am
Curses, Robert is right again |
1st Jul, 2009 at 11:44:35am
On 1st Jul, 2009 turbominivanman said:
2. The other outlet should be connected to the actuator via whatever boost controller / bleed valve you are fitting, if at all. I'm using a GReddy Profec B2. The outlet pipe should also feed the signal to the Dump Valve, or the DV should at least have its own line from the plenum. Importantly, the signal to operate the DV needs to be before the throttle disc rather than after it in order for the operation of the DV to be effective in preventing compressor stall and maintaining the RPM of the rotating shaft. blimey you did well to remember all that richard as i was waffling on ,, couple of things ,, id stick the actuator line off the plenum as well and block both the take offs on the snail , and id put the dump valve signal pipe on the vacuum side of the carb ...in the inlet manifold somewhere ,but as you say , on its own seperate take off .otherwize if theres no vacuum to the dump valve on over run , it wont really do much . the dump valve itself ,can be mounted on the plenum or on the pipe from the intercooler . really pleased its going well regards robert Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
1st Jul, 2009 at 06:55:01pm
Will, Ben, Robert - thanks for the points of clarification, I'll make sure they're incorporated on the van.
3rd Jul, 2009 at 02:13:57pm
Will, Ben, Robert.
