Home > General Chat > What are these bits?
richminiturbo.
Member #: 719
Horndean - Near Portsmouth
Been having a rummage through some bits. Came across these, not sure what they are?
Think theyre old mounts from a metro that I took off the turbo lump when initially stripped it.
Can anyone confirm? If so, which is which?
metro engine mounts by the looks of them
As above
Yes, the alloy one goes at the radiator end instead of the small alloy block that holds the radiator/engine mount bracket (a real pain when you swap as they are different thicknesses so the bolts/studs need changing too) and the others are from the other end - can't remember exactly how, but it has something to do with the extra three holes on the back of the later transfer housings.....
richminiturbo.
Member #: 719
Fantastic, cheers fella's!!
