| Home > Help Needed / General Tech Chat > turbo box fitting | |||||||
" alt="User Avatar" width="100" height="100">52 Posts Member #: 1735 Advanced Member morton, lincolnshire |
5th Jul, 2009 at 10:20:42am
lost out on remote side manifold today so going to have to go down the route of fitting a bulkhead box, are these easy enough to to for not so good welder? and will i loose strenght in the bulkhead? |
![]() 115 Posts Member #: 2240 Advanced Member Co.Cavan....Ireland |
5th Jul, 2009 at 11:12:13am
Look down the help needed page,go down about 10 topics from your own to bulkhead box,Lots of info! Bending the rules and ruling the bends,Since 1959 |
280 Posts Member #: 4340 Senior Member sideways, Birmingham |
6th Jul, 2009 at 01:53:38am
was this the side mounted one with the decompression plate on ebay prechance? located in tamworth?
On 15th Dec, 2009 fastcarl said:
sell the lot to me for £70 pounds and i'll let you stand on the outside edge and look on my inner circle of closest frinds, lol carl FOR EVERY WELL THOUGHT OUT AND WELL EXECUTED PRICISION JOB EVER CONCIEVED, YOU CAN GUARANTEE THAT SOMEWHERE IN WALSALL OR THE BLACK COUNTRY THERE WILL BE A BLOKE TRYING TO ACHIVE THE SAME BY MEANS OF "ITIN IT WI LUMP AMAR" |
6th Jul, 2009 at 08:04:54am
If you are not a good welder get someone who IS a good welder to weld the box in for you, it needs to be done right.
6th Jul, 2009 at 10:31:49pm
Problably 1 1/2 hrs work if prepared. Try a local mobile welding firm if in doubt. On 19th Jan, 2010 wil_h said:
7th Jul, 2009 at 01:33:06pm
Are you near Sleeford or (sleaford) never know how to spell it. I have a friend with a restoration and modification firm with a unit up your way. The welder is a magician one of the best I have ever seen. If you want his number let me know. Own the day
10th Jul, 2009 at 10:17:01pm
On 6th Jul, 2009 MONSTER HEDGEHOG said:
was this the side mounted one with the decompression plate on ebay prechance? located in tamworth? no it was a different one to that was a janspeed set up |
10th Jul, 2009 at 10:18:59pm
On 7th Jul, 2009 Mr Joshua said:
Are you near Sleeford or (sleaford) never know how to spell it. I have a friend with a restoration and modification firm with a unit up your way. The welder is a magician one of the best I have ever seen. If you want his number let me know. yea im about 15 miles from sleaford. may need that number if you dont mind sending it as i may need more welding done to the floor got small hole size of a 5pence |
11th Jul, 2009 at 11:54:00am
You have a PM Own the day
